palmgreen57 Samba Member
Posted: Tue Dec 02, 2014 4:25 am Post subject: 383 distributor questions |
Hi,
I'm rebuilding my late 383 distributor for my 53 oval
I'm arrived at this point and not sure about the good way for this assembly ....
I try to follow the vw diagram but it doesn't match with the picture I've take when I openned it
does is it ok like this ? thanks you for your help
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Tue Dec 02, 2014 4:58 am Post subject: |
I always put the condenser between the 2 nuts.
I like to have the first nut hold the bolt in place and make solid contact with the points spring. Then the wire to the coil, followed by the condenser, washer, lock washer and second nut.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Dec 02, 2014 5:06 am Post subject: |
Hi Glen
do you have a pics on the side of it ? to have a clear idea of that
does I should have a bakelit ring in the hole of the body ?
yan |
Glenn Mr. 010
Posted: Tue Dec 02, 2014 5:13 am Post subject: |
The round insulator should fit in the round depression.
Here's a picture of a NOS Bosch 010 so you can see the condenser is between the 2 nuts.
Member #1009
#BlueSquare |
Posted: Tue Dec 02, 2014 5:16 am Post subject: |
ok, I understand but it's your personnal upgrade of it for a better contact ?
normaly it should be like on the diagram ?
Glenn Mr. 010
Posted: Tue Dec 02, 2014 5:17 am Post subject: |
I'm at work and all mot diagrams and pictures are at home. _________________ Glenn
Member #1009
#BlueSquare |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Dec 02, 2014 8:39 pm Post subject: |
Your diagram looks ok. I like to put a little rubber donut on the through bolt where it passes through the distributor body to help insulate it. The bakeolite insulator on the outside of the distributor body is usually a larger outer diameter than the ones you are showing. From outside of distributor body:
rubber donut
bakeolite insulator
washer
nut 7mm od
condenser wire
washer
coil lead wire
washer
2nd nut _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
johan81 Samba Member
Joined: September 28, 2006 Posts: 163 Location: sweden
Posted: Tue Dec 02, 2014 10:05 pm Post subject: |
Glenn what do you use to paint the bodies?
I'm rebuilding a 383 to and need to figure out how to "paint" it. _________________ 52 bug
55 bug
58 bug
64 beach buggy |
Posted: Wed Dec 03, 2014 12:01 am Post subject: |
I'm not Glenn, but can answer your question. Semi gloss black or satin engine paint. A primer was not used. _________________ Roads Scholar &
PDX db Samba Member
Posted: Wed Dec 03, 2014 12:53 am Post subject: |
Does anyone reproduce the tags? |
Glenn Mr. 010
Posted: Wed Dec 03, 2014 5:10 am Post subject: |
Yes, the badges are available from several of us. _________________ Roads Scholar &
Posted: Wed Dec 03, 2014 1:45 pm Post subject: |
Hi tasb , how are you ?
you're right, here what I finally understood :
from the body , you have :
- part 32 insulator rings x 2 small ( who go in the hole of the body to protect the screw from the body )
- part 33 x 1 BIG one insulator ring who go against the body
- part 34 x 2 small metal washer who take the condensor in sandwich to make contact with the screw
- part 35 x 2 groover washer with a nut between
- etc ...... |
