Speedmaster copy = SS Super Speed wheel
Page: Previous  1, 2, 3
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
mkparker
mkparker is offline
PostPosted: Sat Nov 15, 2014 7:35 am    Post subject: Reply with quote
What size tires did you end up with subgraphic? They look fantastic!
Michael
Pit Boy 6163 Spec Trophy Truck
subgraphic
subgraphic is offline
PostPosted: Tue Nov 18, 2014 8:16 pm    Post subject: Reply with quote
Thanks!
I ended up taking luckystiff's advice and going with 165/60/15 for the front and 195/65/15 on the back. I'm glad I did, I love the way they look. I have a little bit of room in the rear so I might add a spacer to get closer to the lip, but I didn't want to chance it with a wider tire.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
twoodson
twoodson is offline
PostPosted: Mon Dec 01, 2014 1:52 pm    Post subject: Reply with quote
subgraphic or quickbms - can either of you guys tell me if the wheel is too wide to fit in the spare tire area of the car? My car is a 1970 Type 1 Std. Thanks a bunch!
subgraphic
PostPosted: Mon Dec 01, 2014 10:18 pm    Post subject: Reply with quote
Sorry man, they are bolted on the car and won't be coming off for a while. I didn't try to put it in there before they were installed.
Good luck
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Dec 02, 2014 6:52 am    Post subject: Reply with quote
Usually a 4.5 will fit in the spare tire slot with a low profile tire.
A 5.5 is a squeeze.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
twoodson
twoodson is offline
PostPosted: Sun Dec 07, 2014 7:46 pm    Post subject: Reply with quote
subgraphic: thanks for response
Volkswagnut: thanks for the information
I ordered 5 of them and will pick them up tomorrow so I will find out once i get the home to see what happens. I will see if the wheel itself will fit in the spare tire area and then will probable have to install a 135 or 145 tire on the wheel. Again thanks
luckystiff
luckystiff is offline
PostPosted: Mon Dec 08, 2014 5:43 pm    Post subject: Reply with quote
a stock 165r15 fits in the spare area. 165mm =6.5". a 5.5" wide wheel measures 6.5" outside lip to outside lip...... so stick with a tire 165mm wide or LESS and it should fit in the spare spot just fine.........
wanna be a little more sure? put a 145/65/15 on that 5.5" and it will stretch and will surely fit........
ITMC
Secret Service
VOLKSWAGNUT
PostPosted: Mon Dec 08, 2014 6:37 pm    Post subject: Reply with quote
Eh.. a 165/15 on a stock 4 and an aftermarket 4.5 is snug under the hood of an undamaged pre 68 Beetle, and some even have to let air out to make it fit well as its a smigge bigger than the stock 5.60-15 bias tire size.
A 145/15 and 155/15 fit well.
Using a 5.5 wheel makes things snugger, but can be used with the right tire combo.
aka Ken {o\!/o}
rastaguam
rastaguam is offline
PostPosted: Mon Dec 08, 2014 11:05 pm    Post subject: Here's my 1960 DC running 17's. Fit like a glove!!! Reply with quote
57HotrodVW
57HotrodVW is offline
PostPosted: Sun Sep 24, 2017 8:28 am    Post subject: Re: Here's my 1960 DC running 17's. Fit like a glove!!! Reply with quote
rastaguam wrote:
Nice!
Are these the "sand brushed" or "gun metal" finish?
Some of the pics of the CIP wheels I've seen look darker, and some look lighter. I don't want a super light or super dark gray, but a shade in between.
In the pics of your bus here, they look like what I want.
Also, has anyone been able to compare the Speed Master wheels directly to the CIP wheels? I'm interesting I'm knowing about the quality, finish, and weight of one versus the other.
Ellis Engineering
Speedshots Motorsports Photography
Quickbms
Quickbms is offline
PostPosted: Sun Sep 24, 2017 2:29 pm    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
I painted mine for some bling.
Critter1
Critter1 is offline
PostPosted: Mon Jun 24, 2019 10:17 pm    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
5x130 powdercoated bronze
Justin
vwfye
vwfye is offline
PostPosted: Fri May 20, 2022 11:26 am    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
They come in 4 lug as well Cool .
175/55/15 front and 23.5x8.5 M&H rear
64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3"
Mike-O-Rama
Banned
Mike-O-Rama is offline
PostPosted: Sat May 21, 2022 4:42 pm    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
Just picked up a set from CIP for my 69
15x5.5 all around
+25 offset , 4.23 inch backspace all around
205/65/15 Rear Tires
175/65/15 Front Tires
2" Narrowed beam with drop spindles and air shocks in the front
EMPI disc brakes front and rear, no wheel spacers needed
https://www2.cip1.com/c32-ss4130-5515-sb/
torchwerks
torchwerks is offline
PostPosted: Tue Nov 08, 2022 2:25 pm    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
From the CIP site, you only get a head on view.
Can these be widened?
I think they might look pretty good on my buggy, maybe 8 inches wide.
I'd want a 275/60/15 on it.
bonzai272
bonzai272 is offline
PostPosted: Fri Dec 15, 2023 2:10 pm    Post subject: Re: Speedmaster copy = SS Super Speed wheel Reply with quote
Just put these from CIP1 on my Oval recently. Love them.
1955 Beetle
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 3 of 3
