1967250s Samba Member
Posted: Mon Dec 08, 2014 11:10 am Post subject: |
Biscuit79 wrote: |
Random question; the plastic piece that connects the 2 flaps for the front fresh air vents on my 79 broke. I searched quite a bit on forums here but can't find anything. Does anyone know where I can find a replacement? |
Do you mean the ducts? They can be found in the classifieds, or try some of the recyclers listed. _________________ '72 Elm Green Deluxe |
Tcash Samba Member
busdaddy Samba Member
Posted: Mon Dec 08, 2014 3:05 pm Post subject: |
I think we are discussing the plastic link between the flaps behind the front grill on late bays, a cylindrical part about 1" dia and 2" long with a rectangular hole in each end. It's NLA unless you can find one from a parts bus. Copper tubing with the ends squashed partially makes a reasonable substitute. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Biscuit79 Samba Member
Joined: June 05, 2014 Posts: 25 Location: Grand Rapids, MI
Posted: Mon Dec 08, 2014 4:46 pm Post subject: |
thats exactly what I was looking for busdaddy- thanks a bunch!! |
philbrickvw Samba Member
Joined: January 25, 2004 Posts: 107 Location: Iowa City, Iowa
Posted: Mon Dec 08, 2014 4:57 pm Post subject: Solex dual carbs |
I'm a little embarrassed this detail escaped me so far. I just got a set of H32/34 PDSI Brazilian solex carbs and have had no end to troubles. I now see an issue. -2 is the left (drivers side in the US) and -3 is the right.
What would happen if you put the -3 on the left and the -2 on the right?
Hopefully putting them on right will solve my problems.... _________________ 1972 Riviera
1974 Transporter
2012 Routan
2015 Golf Sportwagen TDI
2019 Mini Cooper S |
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Mon Dec 08, 2014 10:54 pm Post subject: |
1967250s wrote: |
Biscuit79 wrote: |
Do you mean the ducts? They can be found in the classifieds, or try some of the recyclers listed. |
While going thru a PILE of classifieds last nite.. I did see an entire fresh air flap assembly. But seems like an easy enuf part to make at home. I'm still working on getting rubber gaskets / foam on those that will seal off the air when I close the flaps. Driving over mountain passes in the middle of winter gets really cold when sub freezing air is whistling thru those vents!
http://www.thesamba.com/vw/classifieds/detail.php?id=1710968 _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Thu Dec 11, 2014 7:49 pm Post subject: |
blue72beetle wrote: |
Is there a difference between a single port 1600 muffler and a dual port 1600 muffler?
Specifically, would this work on my stock 71 dual port?
http://www.thesamba.com/vw/classifieds/detail.php?id=1711774
I do know that 1500 mufflers won't work on a 1600. Found that out the hard way.... |
Yes it will and you should jump on that as fast as you can, smok'n deal for a real deal German muffler, giddyup! I put a similar one on mine this spring and it's absolute bliss, quieter and a better fit.
BTW 1500 mufflers fit 1600's just fine, it's the 1200's that are too narrow. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Thu Dec 11, 2014 11:18 pm Post subject: |
busdaddy wrote: |
BTW 1500 mufflers fit 1600's just fine, it's the 1200's that are too narrow. |
Holy crap, I wish that was local, that is cheap! _________________ How to Post Photos
Play Time Samba Member
Joined: December 07, 2014 Posts: 4 Location: South Africa
Posted: Thu Dec 11, 2014 11:39 pm Post subject: What model pls |
Found this behind driver seat on a VW Kombi Double cab…..what does it mean etc…model etc.. |
Posted: Fri Dec 12, 2014 12:01 am Post subject: |
busdaddy wrote: |
You're right, it was a '40 horse' muffler I bought that didn't fit. Forgot that was 1200cc. _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
Tcash Samba Member
Posted: Fri Dec 12, 2014 9:00 am Post subject: Re: What model pls |
Play Time wrote: |
26 = Pick-Up
2-2 = 1972
120 911 Sequential serial number
For some parts of the world. Vehicles where shipped in parts and assembled in the destined country. |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Wed Dec 17, 2014 6:28 pm Post subject: stupid heater duct ?, '73 westy. |
There is a central pipe under the bus carrying hot (?) air forward. In front of the front cross beam a flexi paper pipe splits off to the shotgun side and goes up into a rectangular metal cross duct. There seems to be a control flap at that junction with a cable going forward. So what does that cable connect to and where does the hot (?) air come out inside the bus (from the flexi tube and rectangular cross duct)? I can't find any outlets (and it won't be running for some time.)
THanks! |
white74westy Samba Member
Posted: Wed Dec 17, 2014 7:30 pm Post subject: Re: stupid heater duct ?, '73 westy. |
PITApan wrote: |
THanks! |
Hopefully this helps: http://www.ratwell.com/technical/Heating.html |
airschooled Air-Schooled
Posted: Wed Dec 17, 2014 10:27 pm Post subject: |
busdaddy wrote: |
You're right, it was a '40 horse' muffler I bought that didn't fit. Forgot that was 1200cc. |
Are you going to buy that muffler? I just saw this thread; I've already called the seller, but I'll pass if you need it. I was only going to pick it up because it's cheap and on my way home from work.
www.airschooled.com |
Posted: Thu Dec 18, 2014 12:01 am Post subject: Re: stupid heater duct ?, '73 westy. |
white74westy wrote: |
PITApan wrote: |
THanks! |
Thanks. I've been all through that site. He doesn't say anything about anything forward of a gas heater.
Has an odd way of making gaskets in this day and age too. Molded silicone gaskets don't dry out, seal perfectly and are cheap and easy to make. I've been using home molded ones against low pressure oil (rocker covers). Air is a snap. |
Posted: Thu Dec 18, 2014 2:42 am Post subject: |
asiab3 wrote: |
Robbie |
PM sent _________________ -Andy-
-1970 Ghia-
kevinj73us Samba Member
Joined: September 25, 2011 Posts: 228 Location: Laurel, MD
Posted: Thu Dec 18, 2014 5:51 am Post subject: Re: stupid heater duct ?, '73 westy. |
PITApan wrote: |
THanks! |
I think you are talking about the flexi pipe that feeds the center heat vent. Between the front seats on the floor is where that comes out.
Is it part 12 here?
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/2-012.jpg
kj _________________ 1973 Station Wagon
m-plate |
Posted: Thu Dec 18, 2014 12:04 pm Post subject: Re: stupid heater duct ?, '73 westy. |
kevinj73us wrote: |
PITApan wrote: |
THanks! |
Is it part 12 here?
kj |
Yes, part 12.
Which way does the outlet between the seats on the floor face, front or rear? |
