Everett's Air Cooled Samba Member
Joined: June 21, 2012 Posts: 16 Location: Burlington NC
Posted: Fri Dec 19, 2014 7:37 am Post subject: Empi Disc brakes with drop spindles |
So i built a narrowed and adjustable beam for a customer and added a Empi disc brake and drop spindle kit. Everything bolted up great and looks just as good. Now for the problem. Empi states in their ad that this kit adds 1/4'' of width to each side, 5/8'' over all. Now I have checked every ruler, and tape measure I own, and all of them come up to 1/2'' when you add 1/4'' and a 1/4''. Either way this isn't the problem. The problem is I have measured and have 1'' over on each side with a grand total of, you guessed it 2''. I contacted empi and explained what I have and was told that they advertise 5/8''. I asked if it was 5/8'' over all or 5/8'' on each side? I was told 5/8'' each side, and that there are many variables that could give me 1'' over. They even mentioned the control arms being wrong. So here are the measurements I took, taking the control arms out of the equation.
subhuman Samba Member
Joined: January 22, 2008 Posts: 538 Location: north carolina
Posted: Fri Dec 19, 2014 7:48 am Post subject: Re: Empi Disc brakes with drop spindles |
Everett's Air Cooled wrote: |
drop spindles ad 1/2 inch per side also, i believe. maybe thats where the added track is coming from.? _________________ 63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain |
Posted: Fri Dec 19, 2014 8:43 am Post subject: |
I asked and was told by Empi it was 5/8'' on each side. Basically Empi said we stated in the ad that it adds 5/8'', but what they don't say in the ad is that it is 5/8'' on each side. CB states 7/8'' on either side. This is one of the reasons we opted for the Empi kit. I guess I will just have to build a narrower beam. Here is the finished beam that is now only 1 1/2'' narrower then stock due to the brakes.
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Wed Dec 24, 2014 4:55 pm Post subject: |
Im not sure what brake setup that is, but I bought the newly designed wide 5 kit a couple years ago...also advertised as "0 offset." Its marketing hype. I don't think there is a true 0 offset disc setup. Mine was close to 2" extra track on a 2" beam. It does stink this happens but you have to expect that from places like Empi and aftermarket parts. I bought my Empi kit due to the fact that every other manufacturer was a bit more money. Sorry you have to cut again...your front end looks good! |
Posted: Tue Dec 30, 2014 11:31 am Post subject: |
It would be nice if Empi would give a true measurement in their advertisements. Here is the solution to the problem. 6.5'' narrowed beam.
