Tercin Samba Member
Joined: August 10, 2008 Posts: 14 Location: Festus MO
Posted: Tue Dec 16, 2014 11:39 am Post subject: 36 hp in a 69 Bug |
Will a 36 hp case bolt up to an IRS transmission in a 69 bug
Thanks |
Danwvw Samba Member
Posted: Tue Dec 16, 2014 12:15 pm Post subject: |
It will bolt up fine but the clutch, flywheel and starter will not match. So you will need to go one way or the other with them. Are you planning keeping the 6 volt generator? I would check with Mofoco but I am not sure the flywheel will work with a 36 horse! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Tercin Samba Member
Posted: Tue Dec 16, 2014 2:14 pm Post subject: |
I am still working all of that out. I am trying to put together a 36 hp challenge car for Bonneville in 2016 I am open to any suggestions |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Dec 16, 2014 2:24 pm Post subject: |
been here
http://www.thesamba.com/vw/forum/viewforum.php?f=44 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Brian Samba Moderator
Posted: Tue Dec 16, 2014 3:35 pm Post subject: |
I was going to ask why, but alright.
Why not a sing axle box? that's what I would use for a straight line racer. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Tercin Samba Member
Posted: Tue Dec 16, 2014 7:09 pm Post subject: |
I am not opposed to a swing axle, but I already have a car with a tranny. |
Tercin Samba Member
Posted: Tue Dec 16, 2014 7:11 pm Post subject: |
Thanks that will be a help |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Fri Dec 19, 2014 11:19 am Post subject: Re: 36 hp in a 69 Bug |
Tercin wrote: |
Thanks |
Perfect car to do a 36hp challenge car with. The swap is very easy with the most expensive part being a 90mm 12 volt generator. Those can be found in the classifieds here or you can get one off Ebay. The starter can be taken care of with either a 12 volt starter with a 6 volt drive gear, or by having a 12 volt ring gear put on your flywheel (Rimco does that). The only differences with the clutch is in size only (180mm vs 200mm). The 180mm clutch will work fine on the IRS gearbox. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Tercin Samba Member
Posted: Wed Dec 24, 2014 9:06 pm Post subject: |
Thanks for the info Mr.Motorhead, I sent you a pm we met at world of speed, I was with the green Rampage. |
