Smurf Samba Member
Joined: January 20, 2004 Posts: 914 Location: Colmar, PA
Posted: Fri Dec 19, 2014 12:00 pm Post subject: Fender mounting rust |
Has anyone ever replaced the metal where the fender gets bolted to?
Is there a plate with a nut welded to it and then put in place in the wheel well area? Kinda hard to explain without visually seeing it I guess lol _________________ 1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Fri Dec 19, 2014 8:48 pm Post subject: |
no good pics in my gallery. There are nuts welded behind the sheet metal around the inner lip of the fender. once you remove the fender, you will see them no problem. i believe they may be on a larger plate. been too long since I had mine opened up. easy enough to cut out sheet metal area around nut. Then get piece of sheet metal, drill through little larger hole than bolt, weld not to sheet metal, then weld in sheet metal. very easy fix if you have some basic fab skills. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sat Dec 20, 2014 7:52 am Post subject: |
Here is how brother Ron installs them
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sat Dec 20, 2014 8:04 am Post subject: |
Another McMaster Carr product. After you weld in take a hammer and knock down level. This is when you don't need to get behind to weld a nut in. |
Smurf Samba Member
Posted: Mon Dec 22, 2014 9:59 am Post subject: |
My fender mounting areas are basically all gone
A lot of great products from mcmaster carr...thanks for the responses! _________________ 1962 Beetle
-Men at Work |
