SixStringMadMan Samba Member
Joined: December 02, 2011 Posts: 263 Location: Roseville, CA
Posted: Fri Dec 19, 2014 3:00 pm Post subject: Question about some parts I'm thinking of ordering. |
I have a '78 Kombi and was making pretty good progress for a while, then life snuck up on me earlier this year and put things on hold. I will be able to spend a bit of time on my bus soon and was thinking about ordering some things from BusDepot for a Christmas gift for myself. With some of the threads I've seen in the past about the quality of repro parts, I was wondering if anyone could look over this list and let me know if these parts would be ok for my bus or if I would be better off avoiding them.
Thanks in advance!
both my fresh air hoses are shot and in many pieces
Oval Engine tin seal 021119337
Heater blower hose left 211261235A
Heater blower hose right 211261236
rear side marker housings and lenses are shot
Rear side marker housing X2 211945351A
Rear side marker lens X2 211945363B
missing this boot
Gear shift boot 111711115A
missing these grommets also
Sliding door grommet J10969
Sliding door buffer 211843471 (not sure if I need this or not)
Sliding door lock grommet 281843718A
tail gate lock gasket J11264
pedal pads are severely worn
Pedal pad X2 211721173
accelerator pedal could use some love
Accelerator pedal repair kit J13009 (mine is old and held together with a nail...)
only have one key and it's bent pretty good...
VW Key blank 19.99
missing this part
Alternator cover plate insert 02111929501C _________________ 1978 Kombi
http://www.vw-mplate.com/mplate-10020.htm |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Dec 19, 2014 3:44 pm Post subject: |
Yeah -- all those nice little bits and bobs that are MIA and needed. Good list.
One thing on the key blank... if it's steel, there are some places that will not cut it. I ran into that with my local lock shop. They cut keys to code just fine, but they will not use steel blanks. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Fri Dec 19, 2014 3:52 pm Post subject: |
jtauxe wrote: |
One thing on the key blank... if it's steel, there are some places that will not cut it. I ran into that with my local lock shop. They cut keys to code just fine, but they will not use steel blanks. |
If you haven't already ordered the key, id just send the door codes to gabriel at gabvwkey.com . I just got a key cut to code for my 77 westy including shipping for right at 20 bucks. Might be cheaper than ordering the blank and then having someone do the work
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Sat Dec 20, 2014 7:23 am Post subject: |
I just installed the oval tin seal (and the circular one on the other side too) both were good parts _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Tcash Samba Member
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Dec 20, 2014 8:12 am Post subject: |
I have not ordered all of the parts on your list, but have bought about half of what you listed. Everything on there that I did buy was a good fit, (exceptions noted below) and decent quality. Bus Depot has pretty good customer service. They also try to use VW part numbers, so that helps with referencing.
I think the parts with the J prefix are usually from Just Kampers, a British company. I placed my first direct order with JK this week. Seems to be going smoothly thus far.
The quality problems I have experienced: The rear side markers have fit-up problems. The gasket is usually a poor fit, like it is too thick. The plastic lug fastener is also a poor design. Other than that, the lens and color is good, but I think the trim is wrong? Silver instead of black, or vice versa. There is a thread about these and how to make them work... better search that!
I bought engine deck lid hinge seals from BD, and they were a JK product. Poor formed fit, and they shrunk weirdly after a month so they don't look right. Modern rubber problems?
Also bought engine deck lid door seal, highest quality. Fit and feel was great, but less than two years later the rubber is starting to crack. |
Posted: Sat Dec 20, 2014 12:26 pm Post subject: |
aerosurfer wrote: |
I just installed the oval tin seal (and the circular one on the other side too) both were good parts |
do you happen to have the part# for the circular one? can't seem to find it on their site. _________________ 1978 Kombi
Posted: Sat Dec 20, 2014 12:27 pm Post subject: |
Wasted youth wrote: |
Thanks for the heads up on the side marker issues. I'll try and locate that thread and give it a read. _________________ 1978 Kombi
Tcash Samba Member
Posted: Sat Dec 20, 2014 1:40 pm Post subject: |
The quality problems I have experienced. The rear side markers have fit-up problems. The gasket is usually a poor fit, like it is too thick. The plastic lug fastener is also a poor design.
I cut the plastic lugs off, drilled holes and put a machine screws, nuts and washers. After initially tightening them up, I cinched them up, on a couple of hot days. It pulled the gasket down to where it was acceptable.
Chassis# 2162 090 464, early 1976 they changed to black rims. Previously they where silver (chrome). |
Posted: Sat Dec 20, 2014 1:53 pm Post subject: |
Tcash wrote: |
Did not know that! |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Sat Dec 20, 2014 7:49 pm Post subject: Re: Question about some parts I'm thinking of ordering. |
SixStringMadMan wrote: |
I bought this for my bus. It works fine. I should've bought a new pedal as mine was beat up but I managed to work the pin into it and it works fine now.
Keep in mind its originally welded to the floor. I don't have a welder yet so I cut the old one off and bolted the new one down. _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Sun Dec 21, 2014 4:27 am Post subject: Re: Question about some parts I'm thinking of ordering. |
Thanks in advance!
missing this boot
VW Key blank 19.99
missing this part
Alternator cover plate insert 02111929501C |
I'm new to bus depot but so far I'm unimpressed/disappointed.
The washer kit I got was Chinese junk. (ENPI) Not worth returning so I'll use it until it breaks and then get one from a flaps. get to see what I am buying before I pay for it.
I got the alternator adjustment bolt plate that is on you list. It seems fine. But after looking at it, I shoulda made one.
I got a thermostat and it's completely the wrong item, even though they claim on their site it's the right one. Others know of what they are selling and advised me, but too late. Still unsure how to handle this one.
Got an engine compartment repair section that turned out to be anything but what they describes. Even the description printed on it didn't match. Customer service was fine and I'm returning it but it's costing me $14 to learn not to trust their descriptions. I pulled some items out of my next order because I realize tey will be either the poorest quality (the h4 headlights) or likely not to fit (the windshield wipers.). A lesson learned; you get what you pay for and these guys will dish that one up in spades. Where they offer several "quality" levels at different prices I feel more comfortable. That's honest. But it seems other places you just need to look at the price and get the idea. Real Cibie headlights are $80 each. Their generic repros are $35 a pair. Even ratwell warns against those, but they'll cheerfully sell you some.
Then there were the backorders and drop ships. The order arrived within the 10 days expected for ground service----but the "drop shipped" items came in a week later. There seems to be a lot they don't stock and they don't order it until you do.
One item, some grommet, is backordered 1-2 months. Site still says ships in 1-3 days. I'd call and check availability on every item you order and triple check if it is the proper part for what you want to do. |
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Mon Dec 22, 2014 2:36 am Post subject: Re: Keys |
You might try checking your local locksmith also. I just had four keys made with the exact same Ilco blanks shown in the ad and I think I paid $3.75 each. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Posted: Mon Dec 22, 2014 10:49 am Post subject: Re: Keys |
oscarsnapkin wrote: |
You might try checking your local locksmith also. I just had four keys made with the exact same Ilco blanks shown in the ad and I think I paid $3.75 each. |
Thanks for this suggestion. I found a local highly rated locksmith and I'm going to give them a shot at making some ignition key copies for me. Once that's done I am going to attempt to make the other locks match the ignition in hopes of only having one key.
Placed my parts order this morning and hopefully it will be on its way soon. Didn't get everything on my list but got most of it. Looking forward to checking out of work for a week or so and getting my hands dirty! _________________ 1978 Kombi
jtauxe Samba Member
Posted: Mon Dec 22, 2014 11:25 am Post subject: Re: Keys |
Placed my parts order this morning and hopefully it will be on its way soon. Didn't get everything on my list but got most of it. Looking forward to checking out of work for a week or so and getting my hands dirty! |
My local locksmith is happy to cut one to code (though he makes me show my driver's license and registration first -- he goes by the book!), and then use that original to make copies. The code-cut key is about $20, and the copies are about $3. Then i keep the original in the file with the paperwork, and never use it except for copying. _________________ John
http://vw.tauxe.net
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Mon Dec 22, 2014 11:40 am Post subject: Re: Question about some parts I'm thinking of ordering. |
PITApan wrote: |
Came in to say this. Haven't had any problems w/ quality, etc but I wish their site was more accurate in regards to stock and ship times. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
Esher127 Samba Member
Joined: August 26, 2010 Posts: 607 Location: Staunton, VA
Posted: Tue Dec 23, 2014 7:11 am Post subject: Re: Question about some parts I'm thinking of ordering. |
... _________________ 1970 Westfalia Pop-Top
