HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Thu Feb 10, 2011 6:30 pm Post subject: |
73SpeedBuggy wrote: |
Yeah, they look great! Do those bolt right onto an IRS chassis? Any downside? |
Hmm, much lighter, disk brakes with integrated parking brakes, slightly wider track, not so hard to find salvage. Only thing I can think of is you really can't modify them very easily and They have that P name on them when you go to get new disks and pads..... _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Feb 10, 2011 8:41 pm Post subject: |
They bolt on to the IRS chassis with - IIRC - an inner bushing change?
I'd have to go back into mine to recall... you have to pay attention to the adjusting bolts where the torsion arms & Porsche trailing arm bolt together; I had to grind down the bolt heads slightly so that they didn't rub the torsion housing shock arms/castings.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
aklauz Samba Member
Posted: Fri Mar 25, 2011 6:41 am Post subject: |
Well all the body fab is done! Side pods have been glassed in with lockable access doors from the inside that came out soooo nice! All the brakes are done, chassis rolling, motor, drive train, suspension all done. Time for paint and final assembly! Starting to look like a real car I'm pretty pumped, Carlisle here I come!
73SpeedBuggy Samba Member
Joined: July 11, 2006 Posts: 874 Location: Warminster, PA
Posted: Fri Mar 25, 2011 1:04 pm Post subject: |
aklauz wrote: |
Lookin good! You've gotta post pics of the access doors, that's a great idea for storage. Can't wait to see it at Carlisle. _________________ Manxter #39 on a 1971 Pan
Turbo-charged Subaru EJ25D (DOHC)
http://www.cardomain.com/ride/3923620/1971-volkswagen-beetle#
-Adam |
aklauz Samba Member
Posted: Fri Jun 17, 2011 8:28 am Post subject: |
Well most the body work is done, doing a final 90% build before giving it back to the body guy for finish paint. Hurdles at every turn!
aklauz Samba Member
Posted: Wed Jun 06, 2012 5:51 am Post subject: |
Well I had a rather large break in this project due to discovering some problems with the chassis then moving across the country and back ha ha However things are really on track now and looking like she'll be a driver in about a week! Here some updated pics and more to come!
Buggy boy Samba Member
Joined: November 16, 2009 Posts: 55 Location: Vancouver Canada
Posted: Wed Jun 06, 2012 4:08 pm Post subject: |
Looks awesome cant wait to see the finsihed product .what is that paint color from? _________________ Anyone who says money can't buy happiness doesn't f--king have any. |
mstevens Samba Member
Joined: January 16, 2008 Posts: 225 Location: Boise, Idaho
Posted: Wed Jun 06, 2012 4:21 pm Post subject: |
Two quick questions for you. What size were the Cragers you were running on it before. And where did you pick up the motor? |
JustBuggy Samba Member
Joined: August 01, 2010 Posts: 849 Location: SF Bay Area, Ca.
Posted: Wed Jun 06, 2012 9:52 pm Post subject: |
How much wider than stock did the "P" trailing arms make it? |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Wed Jun 06, 2012 11:09 pm Post subject: |
You really need to check the set-up and action on your carb linkage. It looks way wrong here. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Thu Jun 07, 2012 5:02 am Post subject: |
Man that looks great!
Where did you get all of the fuel line fittings? Did they bolt on without carb mods? |
aklauz Samba Member
Posted: Thu Jun 07, 2012 6:44 am Post subject: |
The paint is a two stage Dupont Hot Hues Candy Apple Red. The Cragers I used to run were 14" in front and 15x12 in the rear, the motor was built by Mark Wolter at Strictly Foreign. The rear end is about 4" wider on each side with the Porsche trailing arms. The carb linkage is dead on for full throw and the fuel fitting are standard AN onto the webers I hope to have some more pics up soon as its much further along now. |
aklauz Samba Member
Posted: Tue Jun 12, 2012 7:50 am Post subject: |
I'm picking her up tonight!!!!!!!!!!!!!!! I can't tell if I'm more excited or nervous at this point after a 7yr process ha ha |
skorchindustries Samba Member
Joined: August 06, 2012 Posts: 20 Location: Granada Hills
Posted: Sat Dec 20, 2014 11:43 am Post subject: |
Nice build! |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Dec 20, 2014 12:31 pm Post subject: |
I agree with John on linkage. It should be straight up and down or you will wear the throttle bores out in a short time.
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
joescoolcustoms Samba Member
Posted: Sat Dec 20, 2014 1:36 pm Post subject: |
Agree on the linkage.
But, some body's are so tight fitting dual carbs that they have to be pulled in like that to clear the back of the body. If I had not put a body lift on my Manx II, this linkage would not have fit mine with the drop rods perpendicular.
I get into that situation again, I will go sync-link. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Sat Dec 20, 2014 3:42 pm Post subject: |
joescoolcustoms wrote: |
I get into that situation again, I will go sync-link. |
Oh, yes. That SyncLink is trick as all get out. All pulleys and cables... A thing of beauty.
aklauz; your thread got me in my shop today. Didn't do much but I did something. Thank you for the inspiration.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
aklauz Samba Member
Posted: Sun Dec 21, 2014 7:18 am Post subject: |
Mike I'm glad I could inspire ya! I actually am using sync link now and it's really awesome. No more binding Unfortunately this winter I'm rebuilding my motor because I blew the bottom end in the fall, sucked. It's always something!
-Anthony |
