onesweet63 Samba Member
Joined: October 26, 2009 Posts: 46 Location: columbus ohio
Posted: Sun Dec 28, 2014 2:39 am Post subject: |
i have made several pairs of 15x7 rims on short tube axles. my current car is a 61 beryl green bug with im thinkin 2 or 3 clicks. set the rims at factory backspace run a 195/60/15.. i still have enough room to go 8" |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Sun Dec 28, 2014 10:27 am Post subject: |
What rim shells are you using? Thanks _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Grendelspop Samba Member
Joined: June 09, 2009 Posts: 210 Location: Knoxville Tennessee
Posted: Mon Dec 29, 2014 4:01 pm Post subject: |
I eventually made mine. I used junkyard Chevy wheels. 6.5 inch barrels. Cut the centers out replaced with smoothie centers, spun them on the car while on stands and trued them up that way. Welded when done. I'm no pro but took care in my welding and they have been fine for as long as this post is old. That's them in my profile pic... |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Dec 29, 2014 5:56 pm Post subject: |
onesweet63 wrote: |
I've made several sets of widened smoothies for VW's, both short axle and long axle beetles. I will tell you that with factory offset, on a short axle car, an 8" shell is going to hit the fender badly. IF you pull the backspacing to a tight to the spring plate as it will go, 3.75" then the tire may rub the spring plate, and an 8" rim will just barely tuck, depending on the tire you use.
In reality, a 6.5 or 7" wheel hoop is an easier fit, and will give you more tire than 99% of drivers need |
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Thu Jan 01, 2015 10:47 am Post subject: |
Any tips on which "donor" wheel hoops to search for? Like year model Chevy or ?? _________________ Michael
Pit Boy 6163 Spec Trophy Truck |
Posted: Thu Jan 01, 2015 11:15 am Post subject: |
For 15x8 Chevy truck rally wheels. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
