karfer67 Samba Member
Posted: Tue Mar 22, 2005 4:46 pm Post subject: front tires rub when turning |
this is driving me nuts and wondering what i can do to change this. when i turn to go into a parking lot the tires always scrape. i did notice the other day that the passenger side is lower than the driverside which i want to equal out. it is only the fronts that rub and the tires are 145's. would swaping to 135's make a big difference? also the wheels i have are empi 8 spokes. not sure how much the front has been lowered looks like two clicks to me but as i said the passenger side is lower by about 1/2 to 3/4 of an inch. _________________ aircooled for life (1972 squareback cal look) |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Tue Mar 22, 2005 4:55 pm Post subject: |
I'm down 2 in front w/ 165's & I get the same. My thoughts:
135's may help a little, but I think it's the wheels. Personally, I don't like 135's but that's just me. I think the 8 spokes push the wheel outwards.
Do a search on "backspacing" and you'll find lots of discussion about wheels.
I'd bet the "leaning" is due to the car resting on the lower bumpstops. They will disintergrate. Probably one side of yours already has. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Wed Mar 23, 2005 9:46 pm Post subject: |
thanks aircooled but i got a ruler out today and found that the driverside rear is almost 3/4 of an inch higher than the other rear. the fronts were only about 1/4 off so that leads me to believe that if i drop that left rear a tick more it will all even out. as for the tires boy i don't know how you do it with 165 tires. i am running 145s and STILL get some rubbing. _________________ aircooled for life (1972 squareback cal look) |
Joined: March 07, 2002 Posts: 9 Location: Travel arround
Posted: Mon Mar 28, 2005 12:53 pm Post subject: where is it rubbing? |
where is it rubbing? _________________ 62 Notch Pearl white
62 Notch Anthacite
62 Notch Sunroof colour not decided
T25 First Year Deisel
95 T4 Bus LWB
75 Golf cl |
VEEDUBACE Samba Member
Joined: July 01, 2004 Posts: 29 Location: daly city, CA
Posted: Mon Mar 28, 2005 1:23 pm Post subject: |
man, i lowered the front of my 64 notch 2clicks, and i can't even turn my steering wheel at all. i'm running empi 8's w/ 165s. tires rub all over the fenders. i just got some 135s, have to put them on still, i'll keep you posted if they help. forgot to mention that i am running 4lug w/ disc brakes up front. _________________ 66 notchback-hoodride
2002 S-10 Xtreme fully custom daily driver |
rustyfastback Samba Member
Posted: Mon Mar 28, 2005 6:04 pm Post subject: |
I lowered my '65 square 3 outer splines up front, cut the bump stops off. I am running 165's with the stock type 3 wide 5 rims & i get a lot of tire rub. This is a project & I do not drive it much yet. I am going with 135's up front. I think the 8 spokes have an offset for a bug (outward towards the fender) this may be part of the problem. Pics of my '65 can be seen in the gallery just search for photos from rustyfastback. |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Mon Mar 28, 2005 6:24 pm Post subject: |
I'm down one spline running 205's (yeah I know that's fucking wide) with no rub, except ever so slightly on the inner fenders, but they rubbed before I lowered it. _________________ OGST
Samba Member #4862 |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Mon Mar 28, 2005 7:12 pm Post subject: |
VERT similiar thread...in fact too similiar. Same problem, same wheels.
http://www.thesamba.com/vw/forum/viewtopic.php?t=107726 _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
raru Samba Member
Joined: April 16, 2002 Posts: 307 Location: Bay Area, Califaztlan
Posted: Tue Mar 29, 2005 2:04 pm Post subject: |
it's the wheels... i got 145's on stock tires and 2 clicks lowered up front and have no problems... and i got a fat ass too. _________________ Raul
80 Caddy (Gas)
81 Caddy (Diesel)
95 Jetta
98 323is |
Iozzio Samba Member
Joined: March 10, 2005 Posts: 354 Location: Molalla Oregon
Posted: Wed Mar 30, 2005 4:52 am Post subject: |
He's right it is the wheels, those Empi 8's have a huge offset that pushes the wheel to the outside towards the fender. If you were to try a stock steel rim or a Porsche 2 liter wheel it would be alot better. |
