jg4278 Samba Member
Posted: Fri Dec 19, 2014 2:38 pm Post subject: Perego Magica Beetle |
Hi, I recently bought a perego beetle and am trying to make it work firstly. I have bought 2 new batteries and replaced amp fuses but to no avail it still will not work including the lights. The only thing working is the horn. Can anybody help what might be wrong? Thanks jonny |
Wout Samba Member
Joined: November 05, 2008 Posts: 89 Location: Belgium
Posted: Sun Dec 21, 2014 7:04 am Post subject: |
I have 2 and sometimes the switches under the gearshifter are broken or not working fine. But in your case I think the 'key-switch' is the cause. About where the radio is, there's a key or place for a key, check that and I think that's the reason.
Good luck!
gr
Wout _________________ Aircooled vw's for life! |
jg4278 Samba Member
Posted: Mon Dec 29, 2014 4:05 pm Post subject: Perego magica |
Thanks for the reply,
You will be glad to hear I have got it working. My only problem now is that it seems to be one speed works forward and reverse, should it be quicker in 2nd gear? What switch is broken ? Do you know where I can obtain door handles and door mirrors thanks jonny |
HelmutofBuffalo Samba Member
Joined: August 22, 2005 Posts: 554 Location: West Coast of New York
Posted: Wed Jan 07, 2015 8:21 am Post subject: |
I had one of those. Under the hood was a sticker with this 800number for service. It's worth a try 800-728-2108
_________________ 1979 Type I Convertible |
Wout Samba Member
Posted: Sun Mar 08, 2015 5:50 am Post subject: Re: Perego magica |
jg4278 wrote: |
Sorry for the late reply!
Normally the original battery is a combination of 2 6V batteries (my opinion), 1st gear is 6V and 2nd gear 12V. So the switches changes the selection to 1 or 2 parts of the battery in use. I changed one of my cars to a normal car-battery so it's allways 12V , it's burns the wheels when shifting from reverse to forward a bit .
gr
