vweddie Samba Member
Joined: September 22, 2005 Posts: 172 Location: Ky....via El Monte, Ca.
Posted: Thu Oct 23, 2008 10:05 am Post subject: Speedwell BRM center caps? |
Does anyone know where to get the large S speedwell center cap for BRM's? I've seen them on a few cars, but can't find where to get them.
Thanks for any help. _________________ T.B.D.
79 El Camino
12 Scion Tc |
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
Posted: Wed Oct 29, 2008 2:37 pm Post subject: |
Do you guys have any that aren't billet? _________________ T.B.D.
79 El Camino
12 Scion Tc |
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1208 Location: Jakobstad, Finland
Posted: Fri Oct 31, 2008 3:09 am Post subject: |
Just figured if they weren't billet they would be cheaper. But if thats all I can find then I guess thats what I'll get. _________________ T.B.D.
79 El Camino
12 Scion Tc |
Stuggi Samba Member
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 554 Location: Anaheim, CA
Posted: Tue Nov 11, 2008 8:43 pm Post subject: |
FAT Performance in Orange, CA used to sell good copies of the pressed original caps, and may still do. Give them a call.
Al _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
Stevo Wide 5 Samba Member
Joined: August 30, 2000 Posts: 1110 Location: Antwerp, Belgium
Posted: Fri Jan 09, 2015 12:02 pm Post subject: |
Would these clear the end cap on earlier beams?
My original caps don't fit right especially the drivers side with the odometer cable thru it as well!
So i'd like to run these if they would fit with the cable thru it!
Anyone an idea??? _________________ 62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com |
Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Thu Apr 02, 2015 7:25 pm Post subject: |
Having the same problem, the fronts dont fit if you run linkpin front end.
Who else makes ones that will fit?
Thanks |
JohnnyEuro Samba Member
Joined: August 12, 2009 Posts: 62 Location: Easton,PA
Posted: Mon May 18, 2015 10:47 am Post subject: |
Same here, having an issue fitting the cap on the front left.
As a product designer it might be a good idea to add maybe another mil more of material out at the center of the caps - so adjust the outer profile. Then take one cap and machine the inside center in another 2mm for clearance.
Most of us don't have a lathe and these caps are expensive to have to take a Dremel tool to it. I'll have the one "shaved" in by tonight but it's a pain in the arse!
Not as big a deal, just more time consuming - again customer experience is important - I know it may be easier for assembling and getting out the door faster but it'd be nice if I didn't have to take all 3 threaded posts out, have to flip them, then turn 'em back in. This is a minor nit pick though.
Make them fit for all the cars=better product and customer service
Other than that I love them. Would still recommend them.
