My 1963 volksrod Patty
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Fri Apr 18, 2014 6:03 pm    Post subject: Reply with quote
sixfootdan wrote:
It will still be Patty, She is just getting some liposuction. Laughing
What no augmentation or implantation....... geeeeezz... c'mon ... go big...but not too big... Laughing
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Fri May 23, 2014 10:22 am    Post subject: Reply with quote
Moving at a snail's pace but I got the rear cab brace roughed in.
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Sun May 25, 2014 2:08 pm    Post subject: Reply with quote
S
So I'm working on a fuel problem and I realized that Texaco gas in a Mooseheads bottle looks just like Moosehead in a Mooseheads bottle. Could have been a bad deal for me, Just saying. d'oh!
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Thu Dec 25, 2014 6:27 pm    Post subject: Reply with quote
So I decided to raise up the engine and trans in the Bug. I have had all the stuff to do it for many years from my first Volksrod project that I sold. Here is the before pic, You can also see a sneak peek of my new wheel color.
With the 235/75/15's on the back it is 10 1/4" at the lower seam, I'll measure it again when I'm done.
Got lots of cleaning to do and I'm sure there will be some body trimming but the rusty body will be scrapped someday when I finish the Pickup cab.
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Fri Dec 26, 2014 6:36 pm    Post subject: Reply with quote
Today I removed all the gear oil grime from the transaxle and applied it all over myself via a wire wheel on a grinder. Next I removed the nosecone and hockey stick and replaced them with 2" lower bus units.
Next was cutting off the old lower shock mounts. The new drop plate brackets I fabbed up have shock mounts on them.
I installed the modified front and rear trans brackets and here is a pic of one of the dropped spring plate brackets I made.
On the car. The bolts will be replaced with proper lengths and lock washers.
I can see already I'm going to have to cut the inner fender wells, I don't even have the weight of the motor in it yet.
Finally got it to fit.
I did some cutting inside so I'll have to make some new access panels.
I measured the same body seam that was 10 1/4" now it's 7 7/8"
Before and after.
The lowered beam out of my '61 will be going in this one next. Stay tuned Cool
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Sat Jan 03, 2015 10:08 pm    Post subject: Reply with quote
Got the motor back in, I pulled the decklid off because the fanshroud would have hit the hinges. Also the notches for the exhaust don't line up anymore.
This is an old pic before the 2" trans and engine raise. You can see the difference by the gap from the license plate to the tire
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Wed Jan 21, 2015 1:14 pm    Post subject: Reply with quote
Made a cover to hide the nose cone from the trans raise, Still have to trim it.
GO SEAHAWKS!!!
VOLKSWAGNUT
PostPosted: Wed Jan 21, 2015 6:08 pm    Post subject: Reply with quote
Looks good sixfootdan the man..
Trans raise is one of those things I SHOULD have done myself during my own Volksrod build.. d'oh!
Maybe someday.. Ill get back to that... Laughing
aka Ken {o\!/o}
sixfootdan
Samba Smartass
PostPosted: Sun Mar 22, 2015 8:21 am    Post subject: Reply with quote
Patty runs again thanks to a new battery. I still have to finish the mod for the clutch cable and bleed the brakes. I'm moving from a house with a big messy shop to a house with a 2 car garage. I think it will be good for me because it will force me to be more organized. I'm working lots of overtime while trying to move so this project gets put on hold.... again Confused
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Sat Apr 25, 2015 7:20 am    Post subject: Reply with quote
The Volksrod is in it's new smaller laboratory.
GO SEAHAWKS!!!
ovalhobo
ovalhobo is offline
PostPosted: Sat Apr 25, 2015 5:34 pm    Post subject: Reply with quote
Looking great. Those are going to be a pair of wicked rides! I love the look of flat roofs on a volksrod - that scout roof will work nicely! I also love the visor and split windshield you've incorporated into your other ride. I'll definitely be checking in on these two builds!
sixfootdan
Samba Smartass
PostPosted: Sat Apr 25, 2015 5:57 pm    Post subject: Reply with quote
It's actually the same build, I'm going to scrap the sedan body when I ever get around to working on the other cab.
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Sat May 23, 2015 8:31 am    Post subject: Reply with quote
sixfootdan wrote:
I didn't like how this was shaping up so I shit canned the idea. Just running what I have for now.
GO SEAHAWKS!!!
sixfootdan
Samba Smartass
PostPosted: Sat Jul 11, 2015 6:48 am    Post subject: Reply with quote
After 2 or 7 beers out in my laboratory I had an idea. So I went to the drafting table and grabbed some dividers and a sharp pencil. After triple checking all my measurements I came up with this. Laughing
After hunting around on craigslist I found a Keg gas tank and mocked it up.
Next I busted out the tin snips and started cutting.
After closing the hood and trimming the hood 50 times I ended up with this.
The tank is back out for cleaning and plumbing up the sight gauge, To be continued.
GO SEAHAWKS!!!
VOLKSWAGNUT
PostPosted: Sat Jul 11, 2015 12:31 pm    Post subject: Reply with quote
So.... when and where are ya running the copper tubing for that still?
. Laughing
aka Ken {o\!/o}
sixfootdan
Samba Smartass
PostPosted: Sun Jul 12, 2015 8:01 am    Post subject: Reply with quote
. Laughing
HMMMMMMM Think
Got the keg polished up a bit and the sight gauge installed. That's all for this weekend, Off to the Mariners game. Cool
GO SEAHAWKS!!!
EA812
EA812 is offline
PostPosted: Tue Oct 20, 2015 6:25 am    Post subject: Reply with quote
Wow, like sombody said earlier in this thread there is a lot of firsts going on here! I absolutely love the roof visor you fabricated. That is cool. Nice car too.
Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044
Patty B.
Patty B. is offline
PostPosted: Thu Jan 28, 2016 5:03 pm    Post subject: Re: My 1963 volksrod Patty Reply with quote
Cool
jblackburn
jblackburn is offline
PostPosted: Wed Jun 15, 2016 11:35 pm    Post subject: Re: My 1963 volksrod Patty Reply with quote
whoa brand new to the samba and both these builds are some of the wildest volksrods I have ever seen. Hope the build goes well, feeds my imagination very well
Ft. Collins / Denver Metro
1969 Beetle oxidized Savannah Beige
Original 1500CC Single Port
Page 6 of 7
