cwdaniel Samba Member
Posted: Sun Jan 25, 2015 8:38 pm Post subject: 2275, dual idf 44, venturi size? |
Sand car with stock bus trans. Currently the engine is running 34mm vents. would a bump to 36mm kill the bottom too much? Looking for a little more zoom at the top of the hill
Specs:
2275
CB heads 42 x 37 valves. flowed and port matched
TCS 10 cam
1-1/2 exhaust
8.5:1 compression |
Posted: Sun Jan 25, 2015 9:15 pm Post subject: Re: 2275, dual idf 44, venturi size? |
The cam is the problem, not the 34mm venturis. Cam is too small. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Sun Jan 25, 2015 9:29 pm Post subject: Re: 2275, dual idf 44, venturi size? |
[email protected] wrote: |
The cam is the problem, not the 34mm venturis. Cam is too small. |
Ok. So a venturi change will have no effect? A detrimental effect? |
Posted: Sun Jan 25, 2015 10:01 pm Post subject: Re: 2275, dual idf 44, venturi size? |
your engine is such that an increase in venturi size is not going to do anything positive, IMO. _________________ It's just advice, do whatever you want with it!
