GTV Samba Member
Posted: Fri Jan 23, 2015 10:39 pm Post subject: |
_________________ EMPI Power Rules! |
tstevenson Samba Member
Posted: Fri Jan 23, 2015 11:52 pm Post subject: |
I want to reiterate the fact that Mark and Pat were incredibly helpful and responsive when I was troubleshooting. My motor/ignition combo simply did not play nice with the Black Box and its current firmware. I fell into one of the extremely rare use cases that had troubles.
To answer a question that was asked earlier; I have had ZERO issues after switching to the Magnaspark Digital distributor. I had it installed, wired, and software loaded in 30 mins flat. The motor started right up and the distributor has been working flawlessly ever since. No starting hesitations, no starter kickback, rock solid timing at all RPMs and MAPs. A truly amazing and innovative product.
Thank you again CB. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Sun Jan 25, 2015 1:10 pm Post subject: |
tstevenson wrote: |
I also agree that Mark and Pat have been nice and respectful to me through this process and I am not trying to bad mouth them. The fact that you are not having any issues points to something unique about my car, set up or my distributor itself has a problem however I have not been able to figure that out. For the last year I have gone back to a standard distributor.
I thought this latest update with a software fix for the black box would translate to the digital distributor as well since they use the same software, map, similar MAP sensor etc. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
BBMV8 Samba Member
Joined: September 26, 2014 Posts: 12 Location: The Netherlands
Posted: Mon Jan 26, 2015 5:18 am Post subject: |
Good to hear work is being done on a possible software-issue that only a small number of people have.
I would like to take the opportunity to ask if the manual can be updated at the same time.
In below pic, info about the circled items is not present in the manual.
Heck, the 'cylinder selection' item didn't even show most of time in the program, and just pops on occassionally.
When I started to encounter kickbacks, I some spent time trying different numbers but to no avail.
I did by chance found something about this VR-value in some other manual for another CB-product, but not in the blackbox manual.
Pat D Samba Member
Posted: Tue Jan 27, 2015 9:49 am Post subject: |
I am in need of a volunteer to do a test on a software fix for the kick back issue. Since no cars at our facility are having the issue, I need someone who is, to try the fix on their car. Please email me at CB and I will email you the file. It seems that the worst case scenario from feed back is the Pertronix distributor. I would really like someone to do a test using a pertronix distributor and or a pertronix module inside a VW distributor. But, I want to test the file in any car that is having the kick back issue. My email is: [email protected] _________________ Pat, Im too fast slow me downs! |
Dauz Samba Member
Posted: Tue Jan 27, 2015 10:06 am Post subject: |
Pat D wrote: |
I am in need of a volunteer to do a test on a software fix for the kick back issue. Since no cars at our facility are having the issue, I need someone who is, to try the fix on their car. Please email me at CB and I will email you the file. It seems that the worst case scenario from feed back is the Pertronix distributor. I would really like someone to do a test using a pertronix distributor and or a pertronix module inside a VW distributor. But, I want to test the file in any car that is having the kick back issue. My email is: [email protected] |
Are any of the cars at your facility running the Pertronix distributor or VW/Pertronix module? Procurement wouldn't be an issue given the fact that CB resales for Pertronix I'd think.
I'm in IT Networking R&D for a wireless giant here in southern Cali and it's my responsibility to bring into the equation all conditions in my own lab to reproduce, test, and resolve any issues reported by an end-user or encountered in operations. I am not confident in providing a 'fix' for something I've never seen first-hand.
Just thinking with my keyboard. No faith lost in the CB team. |
Pat D Samba Member
Posted: Tue Jan 27, 2015 11:08 am Post subject: |
Dauz wrote: |
Pat D wrote: |
I have done this at CB. It is now ready to be field tested on cars with known problems. _________________ Pat, Im too fast slow me downs! |
Dauz Samba Member
Posted: Tue Jan 27, 2015 12:43 pm Post subject: |
Pat D wrote: |
Dauz wrote: |
Pat D wrote: |
I have done this at CB. It is now ready to be field tested on cars with known problems. |
Ah, roger that! |
Pat D Samba Member
Posted: Thu Jan 29, 2015 1:36 pm Post subject: |
So far, no one who says to be having cranking issues has emailed me to test new software?????? _________________ Pat, Im too fast slow me downs! |
theDrew Samba Member
Posted: Thu Jan 29, 2015 3:46 pm Post subject: |
Pat D wrote: |
So far, no one who says to be having cranking issues has emailed me to test new software?????? |
how do you plan on releasing the fix? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu Jan 29, 2015 9:54 pm Post subject: |
I have to say that although I have never tested the box in question, I am familiar with the kind of issues that may pop up with advanced products like this.
It is no easy task to deliver a thoroughly tested product when all possible combinations of components and workmanship is way beyond testability.
I applaud Pat's humble approach to critics on this forum, others have tons to learn from this.
I hope the problems get resolved for all. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
BBMV8 Samba Member
Posted: Fri Jan 30, 2015 4:44 am Post subject: |
Pat D wrote: |
I would love to test out the updated software on my car.
But since the Blackbox is (still only partially) installed in my dailydriver, swapping in a locked distributor, rewiring and retiming it all takes a fair bit of time.
This is not something I like to do for just testing, and possibly leave me stranded or not able to get to work in the morning. Especially not with the current near freezing wintertemps here.
Also in my case, the kickbacks only started hapening after awhile, not right from the start of the install. |
Pat D Samba Member
Posted: Fri Jan 30, 2015 8:55 am Post subject: |
theDrew wrote: |
Pat D wrote: |
how do you plan on releasing the fix? |
We can email the file and talk you through re flashing the processor. _________________ Pat, Im too fast slow me downs! |
kikkegek Samba Member
Joined: September 27, 2014 Posts: 23 Location: Netherlands
Posted: Wed Feb 04, 2015 12:11 pm Post subject: |
Pat D wrote: |
theDrew wrote: |
Pat D wrote: |
We can email the file and talk you through re flashing the processor. |
oh please do so:
jochenzADDgmail.com
would love to test the update...
BTW, found what was causing my rough idle:
- one bad rubber end-cap on the distributor
- one carb stud was loose. put it back in with #271 red loctite.
should be solid now! |
Pat D Samba Member
Posted: Wed Feb 04, 2015 1:36 pm Post subject: |
kikkegek wrote: |
Pat D wrote: |
theDrew wrote: |
Pat D wrote: |
oh please do so:
jochenzADDgmail.com
Is your email [email protected]? _________________ Pat, Im too fast slow me downs! |
Posted: Wed Feb 04, 2015 1:42 pm Post subject: |
ADD is @
but I didnt want to post my complete emailadres. some forum even forbid it.
so just replace ADD by @ and you got it |
Fred Winterburn Samba Member
Joined: April 17, 2013 Posts: 423 Location: Ripley Ontario Canada
Posted: Wed Feb 04, 2015 3:36 pm Post subject: |
Pat, If this is any help at all, I've found the Pertronix unit to be very susceptible to ac ripple or voltage spikes in the 12V supply. Numerous misfires result. It doesn't result in extra sparks, but fewer sparks, ie complete misfires. Perhaps on starter with the associated voltage spikes that is part of the problem. Something to consider anyway, Fred
Pat D wrote: |
Porsche60 Samba Member
Joined: December 27, 2007 Posts: 210 Location: Far East
Posted: Wed Feb 04, 2015 10:18 pm Post subject: |
Fred Winterburn wrote: |
I've heard that recent Pertronix Ignitor II is not good.
Do you think it is related to the problem?
Pertronix billet distributor has Ignitor II inside.
I had Ignitor II in a Mallory distributor and now I have Ignitor I in a 009.
I think it got better with latter setup but not sure what affected. |
Posted: Sat Feb 14, 2015 8:29 am Post subject: |
anybody tested the new software yet?
I am getting ready to upload it tomorrow. Pretty curious what to expect. |
Posted: Sat Feb 14, 2015 8:54 am Post subject: |
kikkegek wrote: |
have you got the test version?
i'm curious too.
btw, my black box is running well and i feel that the engine warms up faster than last winter.
i have single carb, stock heat riser pipe, but no hot air into the air cleaner.
this makes the engine stall after morning cold start and took a bunch of minutes to warm up.
now, warming up takes only 5 minutes run.
i think this is because of better ignition timing, hotter spark and better AFR.
and those could be achieved by adding the black box. |
