535mcginnis535 Samba Member
Posted: Mon Jan 26, 2015 7:27 am Post subject: Peiseler transaxle tools |
Im looking for a tool number for the peiseler final drive bearing removal/install tool. Also the final drive seal removal/install tool as well
Any info would be greatly appreciated
Thanks
Bill Mc _________________ Bill Mc |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15307 Location: Deep in the 405
Posted: Mon Jan 26, 2015 7:57 am Post subject: |
On the menu bar at the top of this page click on the "Technical" tab and you will find a complete listing of all VW tools. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Jan 26, 2015 10:08 am Post subject: |
Bentley manuals usually have a tool being used in assembly/disassembly, and have the part numbers listed. By final drive, are you talking about the roller bearings on the sides of an IRS diff, and the side cover seals for the CV cups? You can modify a bearing splitter with a flat surface for the diff, and the aluminum wheel bearing race installation tool kits work well for installing the seals. The only time I've ever found any actual VW specialy tools was when a shop was closing up. I started working on transaxles in 2005, and some 10 years later, there are tools I've searched for that I've never found. |
Posted: Mon Jan 26, 2015 3:42 pm Post subject: |
Thanks for the info guys
I just started rebuilding type 1's I've had a few tools made to do the job but having the factory tools would be nice
Thanks again _________________ Bill Mc |
Posted: Mon Jan 26, 2015 3:54 pm Post subject: |
Hey VWracerdave
Do you ever get out to little Sahara state park??
The wife and I or going in late September for a week _________________ Bill Mc |
nsracing Samba Member
Posted: Tue Jan 27, 2015 1:40 pm Post subject: |
which Peiseler tools you need? Swing or IRS? |
Posted: Tue Jan 27, 2015 2:36 pm Post subject: |
Irs type 1 axle bearing outer race install/remove.
Transaxle not trailing arm. 😀👍 _________________ Bill Mc |
Posted: Tue Jan 27, 2015 4:28 pm Post subject: |
535mcginnis535 wrote: |
Hey VWracerdave
Do you ever get out to little Sahara state park?? |
No, I don't play in the sand. I'm a 1/4 mile drag racer. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Jan 27, 2015 5:39 pm Post subject: |
I use regular alluminum bearing race drivers for this. And have for many years _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Jan 27, 2015 7:19 pm Post subject: |
Here's what I found in my Bentley. First image is pressing the old seal out.
Second image is the same tool with the base tool flipped 180 degrees to use the opposite end to press the bearing out.
Third is pressing the new bearing race in.
Fourth shows the seal install, but no tool number. Further in the section a similar tool is shown pressing in the rear wheel bearing seal, which may be the same for the trans since they are only 2mm apart in diameter (60mm to 62mm).
And the last pic is the fixture for removing the bearing from the diff. Then the bearing on the diff cover.
So it looks like that gives you; VW 408a, 473, 401, 459/1, 474, 457/1, 457/2, 454, 456, and 458. All said, and done, maybe $1000+ in actual Peiseler Tools...., if you can find them. Reproductions, along with someone being handy with a lathe could probably get you by for less than a few hundred.
Edit: It looks like in the Technical section vwracerdave suggested, it has VW 473 as an oil seal removal, and installation tool. |
Posted: Wed Jan 28, 2015 4:16 am Post subject: |
It is not that easy to collect all those tools. Had to machine my own.
For bearing races and seals, a regular bearing drift set will work. If it is odd sized, then have the drift machined to size.
But you will need the that stand and plates to remove and R/R lots of things. |
Posted: Wed Jan 28, 2015 6:02 am Post subject: |
After doing a little searching, it looks like someone is offering left over Snap On reproductions. Snap On would be equal in quality to a Pieseler Tool, but you're going to pay Snap On prices. The 456a stand looks like it has two little adapters so you can use it as VW 452. And they do have the 457 plates to go across. But at $380, and $170, they aren't cheap. They also have the 408a, 454, and 473 ranging from about $50 to $110. Here's the link to the 456a.
https://vw.snapon.com/SpecialToolsDetail.aspx?itemId=2790006 |
Posted: Wed Jan 28, 2015 8:18 am Post subject: |
gkeeton Thanks for the pics and info
After looking at the prices and very limited availability I think
my best bet is to have a machinist friend of mine make the bearing drift
And I made a tool for the input shaft seal and final drive seal that works well
Thanks again guys
Posted: Wed Jan 28, 2015 6:24 pm Post subject: |
Mcmscott
I found the aluminum bearing seal kit you talked about.
I checked the sizes and they are right on with the final drive bearing
races and seals. The kit is less then $50 thanks 👍👍 _________________ Bill Mc |
Posted: Wed Jan 28, 2015 7:10 pm Post subject: |
You are welcome! Glad I could help _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
