joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Mon Jan 26, 2015 8:48 am Post subject: widend stock wheels for class 11 |
I am building a beach bug, with class 11 features. I would like wider stock wheels. It is a '71, so 4 hole. I have 3" lifted spindles I might put on, and crank up the back to match. I think I like the look of smoothies. What would be a good wheel/tire size combination? I dont want to deal with a lot of rubbing issues. I see you can buy new 5 1/2" stock wheels from a couple of vendors, is this visually wider? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Brian Samba Moderator
Posted: Mon Jan 26, 2015 1:34 pm Post subject: |
The new 5 1/2" wheels have a smaller offset and will rub in the back. That's what I had.
You'd be fine just using your stock rims. What size tires are you getting? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon Jan 26, 2015 4:00 pm Post subject: |
I am thinking maybe 235/75/15 for the back, and a little smaller for the front. |
Posted: Mon Jan 26, 2015 4:08 pm Post subject: |
I always recommend the setup I had.
215/75-15 front and 235/75-15 rear.
I had 5 1/2" aftermarkets and they would rub the fender when I hit a bump. your stock 4" wheels will do fine I believe. Small wheels give the wheels a round look, which I think is cool. You can see in the picture below where the fender would hit the tire. It wasn't major, but it happened.
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
