camelcrash Samba Member
Joined: February 11, 2011 Posts: 55 Location: Nor Cal
Posted: Mon Jan 26, 2015 12:39 am Post subject: Front beam threw rod question. |
I have a wider off-road front beam and am wondering if anyone has tried to use castle nuts with carter keys on the ends instead of jam nuts, or pinch nuts?
Pros? Cons?
Thanks, Dan _________________ Project in process. All I need is more CASH.
Chenowth Explorer 4 Seater, 1835, 091 Trans |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Mon Jan 26, 2015 1:04 am Post subject: |
Pro: nothing over the pinch nuts
Con: more work to drill holes in the rod for cotter pin
In other words, I wouldn't bother. Go with the pinch nuts. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
77charger Samba Member
Posted: Mon Jan 26, 2015 1:45 pm Post subject: |
jam nuts are simple.easy and work _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Posted: Mon Jan 26, 2015 7:23 pm Post subject: |
I'v used both and recently had some pinch nuts back off. When I tried to tighten them I broke the head off of one of them. Castle nuts just seemed like the most secure way to make sure they won't back off.
Thanks, for the replies. _________________ Project in process. All I need is more CASH.
jsturtlebuggy Samba Member
Posted: Mon Jan 26, 2015 10:17 pm Post subject: |
What are your thru rods made of? Chromoly or a softer material?
The thru rod pinch clamps work well.
On my own I am using Chromoly thru rods with a nut welded on one end and a pinch clamp and a thin jam nylok nut. Never had a problem.
Also are you using Delrin beam bushings or urethane. Delrin does not wear as fast as urethane, so you are not always having to do adjustments on thru rods.
I also use Torrington bearings instead of a nylon washer as bearing surface between the washers under the pinch clamp and other end against the trailing arms. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
