waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Wed Jan 21, 2015 7:36 pm Post subject: Too little end play at flywheel |
I'm putting my flywheel back on after cleaning up my engine. I didn't split the case or even remove the heads - really just gave everything a good cleaning.
I noticed a normal amount of end play by pulling on the pulley wheel when the engine was in the car. I didn't have a dial indicator at the time, but I definitely felt a small amount of movement.
Now that I am putting the flywheel back on, using the same shims that were originally on it, I am only getting .001 - .002 inches of end play (I borrowed a dial indicator). The flywheel barely moves.
What might have happened? I doubt if I over-tightened the gland nut (or if that is even possible).
Before I go and order more shims (and a new main seal), is there something I might have done wrong? _________________ Mike B. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Thu Jan 22, 2015 6:22 pm Post subject: |
make sure you are getting a good reading it should be .003 to .004 . did you replace the main seal ? |
Posted: Thu Jan 22, 2015 11:36 pm Post subject: |
Maybe you have a piece of foreign material between a two of the shims. Just a hair or piece of lint would throw the end play measurement off. |
Posted: Fri Jan 23, 2015 6:42 pm Post subject: |
citroen wrote: |
Yes, I installed a new main seal. I know I should have waited until the end play was set before doing that. I've tried it a few different times now and I'm getting the same reading (.001 - .002).
Here's the set-up I used. I can 'flex' the flywheel to get a reading of up to .010, but when I let off the pressure it returns to between .001 and .002
I'm going to remove the flywheel to check that everything looks OK and give it another try. _________________ Mike B. |
GodJockey Samba Member
Joined: April 03, 2007 Posts: 240 Location: Lehigh Valley, Pa
Posted: Sat Jan 24, 2015 11:02 am Post subject: |
What do you have the flywheel torqued at to test the endplay? The way you are saying you can "flex" the flywheel says to me it may not be torqued enough? |
63single Samba Member
Joined: May 02, 2004 Posts: 122 Location: west coast of fla.
Posted: Sun Jan 25, 2015 4:34 pm Post subject: |
You could be hitting the seal. I say try pushing the seal in a bit more to pick up more clearance. |
Posted: Wed Jan 28, 2015 8:33 am Post subject: |
63single wrote: |
I think that is what was causing the problem. I took the flywheel off and noticed that the seal was protruding a little bit, maybe by a millimeter. I tapped it in so that it was flush with the opening, put the flywheel back on and measured it again. This time I got readings between .003" - .004" (perfect!).
Onward we go! Hope to try and start this engine very soon! _________________ Mike B. |
