usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Mon Feb 16, 2015 10:46 am Post subject: |
2. This is a newer car but the location will be the same I guess.
There are the two little holes. From this view the left is where the speedocable guide is fixed and the right is for the horn cable.
4. There is not much inside.
Just a ring that reduces the diameter a bit but that usually can not be removed
6. The headliner has stripes of cardboard sewed along the edges all around.
They are just hooked behind the metal gaps all around the roof above the Windows.
_________________ Master of my domain!
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Mon Feb 16, 2015 10:54 am Post subject: |
>>> NO. These are for brake switch for 51 hydraulic brakes. <<<
Too much luxury for me!! _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Mon Feb 16, 2015 11:06 am Post subject: |
rod_vw wrote: |
Too much luxury for me!! |
If you want to see it in an older car.
Nothing hydraulic here.
Posted: Mon Feb 16, 2015 11:09 am Post subject: |
virtanen wrote: |
Here a pic of an early fuel tank inside the neck.
When did they change from the small to the bigger hole?
This one is early 1949.
_________________ Master of my domain! |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon Feb 16, 2015 12:49 pm Post subject: |
The routing of the brake light switch wire is the same, hydro or cable. Yes the switch is in a slightly different position, but the wire will reach. Some splits have the small hole next to the fuse box for the wire (750mm brake light switch wire) and some do not and the harness exits out of the spare tire well tab hole on the left side (1150mm brake light switch wire, with grommet in the tab hole even though it is not round, as in the pic above). Some brake light switch wires were aluminum wrapped and some were cloth wrapped. _________________ John Henry
'57 Deluxe
'56 Single Cab |
