BGEE68 Samba Member
Posted: Wed Feb 18, 2015 8:01 pm Post subject: Type 3 rear brakes on a Bug, anyone know the HVWs issue |
Does anyone remember the issue of HVWs that had a tech article for using Type 3 rear brakes on a Bug? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Feb 18, 2015 9:10 pm Post subject: |
You can find all the information in the HBB Off-Road forums. Those guys do it all the time. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Feb 19, 2015 6:53 am Post subject: Re: Type 3 rear brakes on a Bug, anyone know the HVWs issue |
BGEE68 wrote: |
Wow - you seriously think someone really has that type of memory ?????
Well, it turns out that I do have a pornographic memory. Unfortunately, that doesn't help in this case.
So I looked it up for you in my home-built Hot VWs technical index. So you want the August 1999 issue, which has my spreadsheet heading "BRAKES - INSTALLING LARGER TYPE 3 REAR ONTO BUG" _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
BGEE68 Samba Member
Posted: Thu Feb 19, 2015 10:31 am Post subject: Re: Type 3 rear brakes on a Bug, anyone know the HVWs issue |
So I looked it up for you in my home-built Hot VWs technical index. So you want the August 1999 issue, which has my spreadsheet heading "BRAKES - INSTALLING LARGER TYPE 3 REAR ONTO BUG" |
Yes, see I found you :D
I really do appreciate the info:!: :!: :!:
I was installing a set of disc brakes on the rear of my Bonneville Bug, but found the kit doesn't fit very well...And as I have two type 3s, I'm going the direction of the larger type 3 brakes instead of discs... |
