vwsplitvan Samba Member
Posted: Thu Feb 26, 2015 11:13 am Post subject: |
If u have can u add to my current order if not too late.
thanks
Maybe I am wrong Tram _________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3692 Location: San Jose, CA
Posted: Fri Feb 27, 2015 11:58 am Post subject: |
I found a couple 411 853 675 badges. I did my best to take some measurements so you can compare them to your rear hatch. It's shiny, not brushed.
_________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Fri Feb 27, 2015 12:03 pm Post subject: |
Thanks Are the prongs spaced the same distance apart.
Looking for the measurement from prong to prong please then I can check tomorrow.
thanks for taking a look. _________________ SBS #20 UK
Posted: Fri Feb 27, 2015 12:06 pm Post subject: |
From the "A" pin to the "M" pin is roughly 97MM. From the "M" pin to the "C" pin is roughly 85MM. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
Posted: Fri Feb 27, 2015 12:09 pm Post subject: |
down workshop tomorrow so will take a look _________________ SBS #20 UK
Posted: Fri Feb 27, 2015 12:12 pm Post subject: |
Here's the lower case "a" 411 853 675 badge compared to the lower case "a" 311 853 675A badge. 411 badge is in front.
Pins are much larger on the 411 badge.
Follow ISP West on:
Posted: Fri Feb 27, 2015 3:22 pm Post subject: |
It really looks like the 411 version with the larger prongs I will take measurements again tomorrow. _________________ SBS #20 UK
Posted: Sat Feb 28, 2015 8:06 am Post subject: |
That's the one Michael _________________ SBS #20 UK
Boo-Koo-Z Samba Member
Joined: February 03, 2004 Posts: 437 Location: Tri-cities … South Eastern Washington State USA
