electronic ignition
bonampak
bonampak is offline
PostPosted: Fri Apr 08, 2011 5:53 pm    Post subject: electronic ignition Reply with quote
I just installed this electronic ignition, what a difference, not a hickup, so smooth, i wish i had before, no more adjusting, its a day and night feel.
Ian Epperson
Ian Epperson is offline
PostPosted: Fri Apr 08, 2011 5:58 pm    Post subject: Reply with quote
Congrats! It looks clean, what kit is it?
When I swapped out my points for a Petronix module years ago, I swore I'd never wrestle with points again.
VW-181 shirts and stickers.
http://ian.epperson.com/vw
bonampak
bonampak is offline
PostPosted: Fri Apr 08, 2011 6:03 pm    Post subject: electronic ignition Reply with quote
I had no idea it existed, the fantastic and inexpensif mecanic i use in Cancun advised me to switch to this system.
Lettuce
Lettuce is offline
PostPosted: Fri Apr 08, 2011 7:58 pm    Post subject: Reply with quote
that is the oem kit used on mexican beetles. note the vw/audi group coil
cb has it http://www.cbperformance.com/catalog.asp?ProductID=1840
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Apr 08, 2011 8:57 pm    Post subject: Reply with quote
Nice setup
The one that CB sells doesn't look like it has a vacuum advance can.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Captain Pike
Captain Pike is offline
PostPosted: Sat Apr 09, 2011 6:38 am    Post subject: Reply with quote
I made mine from a 1.9 vanagon dizzy.
http://www.thesamba.com/vw/forum/viewtopic.php?t=374830&highlight=
LEARN TO SELF RESCUE
.....................All Current.......................
Lettuce
Lettuce is offline
PostPosted: Sat Apr 09, 2011 1:56 pm    Post subject: Reply with quote
any advantages other than no maintenance? If that is a vangaon distributor, how is it curved ? I will just stick with my compufire
maybe the original poster went from a mechanical only distributor, that would make a big difference with a stock carb.
Captain Pike
PostPosted: Sat Apr 09, 2011 2:24 pm    Post subject: Reply with quote
Advance curve is fine. Timed @5* after/dual biscut. No more tune ups.
Semper_Dad
PostPosted: Sat Apr 09, 2011 2:33 pm    Post subject: Re: electronic ignition Reply with quote
I'd still like to know which distributor the OP is using.
bonampak
bonampak is offline
PostPosted: Sat Apr 09, 2011 2:34 pm    Post subject: Reply with quote
this was my old setup.
ayfreereef
ayfreereef is offline
PostPosted: Sat Feb 28, 2015 11:58 am    Post subject: Reply with quote
I just got the same set up. I was wondering how the wires going to the coil are set up. Does the brown, and green go to the - side and black to the positive?
