mwhayes Samba Member
Joined: February 16, 2009 Posts: 35 Location: Asheboro, NC
Posted: Sat Feb 28, 2015 4:24 pm Post subject: Switched to 28 PCI on my 54, now throttle issue... help |
Switched to a 28 PCI carb and now my throttle cable is sticking. It's like there is not enough tension on the cable? As well the new carb starts and idles great but it's bogging a bit under acceleration.
Any input would be appreciated... |
Posted: Sun Mar 01, 2015 10:26 am Post subject: |
Here is a video of it bogging down. Had to use a spring for now because the stock spring looks like it does not have enough strength close the throttle and bring the pedal back after it's pushed down. I hope the audio is good enough to hear what's happening. I am having to burp the throttle to overcome the carb from bogging down on smooth acceleration. To be clear the carb it bogging down of smooth acceleration and the engine then dies.
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sun Mar 01, 2015 12:29 pm Post subject: |
You'll have to search the classified... |
Posted: Sun Mar 01, 2015 12:31 pm Post subject: |
yes, didn't see any |
txoval Samba Member
Posted: Sun Mar 01, 2015 12:34 pm Post subject: |
Looks like wolfsburg west sells most pieces except the spring.
www.wolfsburgwest.com
Go the fuel system section |
Posted: Sun Mar 01, 2015 12:40 pm Post subject: |
txoval wrote: |
thanks man, I did find some. had my search saved to only look at pre 58'. Found some on this site, will look at the link.
Thanks again |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1747 Location: Winnipeg
Posted: Thu Mar 05, 2015 12:24 pm Post subject: |
Check to see that the accelerator pump is working correctly. Remove the main jet and make sure it is clean of any debris. These are the only things that generally go wrong with these carbs. Both are related to deposits left when old gas evaporates. I see you have a distributor without a vacuum advance, is the port on the carb plugged properly? I would go back to a stock disty myself.
Don _________________ Better and better mistakes! |
Posted: Thu Mar 05, 2015 6:46 pm Post subject: |
I believe it is plugged properly, you mean this is not the stock distributor?
sunroof wrote: |
Don |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Thu Mar 05, 2015 6:52 pm Post subject: |
mwhayes wrote: |
sunroof wrote: |
Don |
The original distributor has a vacuum advance with a metal tube that connects to the right side of the carburetor.
Example
It looks like you have a standard 009?
A 36hp will run ok with an 009 though, as long as the timing is set correctly. You can usually set it to the same as stock - 7.5BDTC _________________ How to Post Photos
Posted: Thu Mar 05, 2015 7:01 pm Post subject: |
I appreciate the response guess I will have to look for one at the swap meets |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Mar 08, 2015 5:09 am Post subject: |
I believe Ev meant right side of the carburetor. Since there is no vacuum line entering the right side of your carburetor its a clue that: It's a little hard to see the distributor in your video but it does appear to be aluminum bodied. The original distributors for this vintage were cast iron, have a vacuum canister and steel line with a Bosch oval badge. The part number VJU 4 R 8 should appear on the badge. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
txoval Samba Member
Posted: Sun Mar 08, 2015 6:55 am Post subject: |
You can use your 009 distributor if the vacuum port on the carb is plugged properly.
Look up Glenn or Ed Fall for a restored stock distributor. They are not cheap, but you can't beat the quality. |
txoval Samba Member
Posted: Sun Mar 08, 2015 5:45 pm Post subject: |
Since I completely missed it, TASB sells quality restored distributors as well! |
