ajam Samba Member
Posted: Fri Feb 27, 2015 9:58 am Post subject: 71 deluxe first car |
This past summer I bought a 71 and I'm currently working on rebuilding the motor, fixing some rust and wiring and PO's questionable decisions. Its been pretty slow since I'm trying to do it without help with money and such but I'm trying to finish it by May when I turn 16. This is the first car I've really done any work on so its all just been learning pretty much. I'm pretty bad at remembering to take pictures but ill do my best.
most of the rust is up front
Thats all I've got right now but I'll try to remember to post more as I go |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Fri Feb 27, 2015 10:18 am Post subject: |
Save your scalp and turn those license plate screws around the other way.
Beetlejay Samba Member
Joined: January 07, 2013 Posts: 14 Location: Pennsylvania
Posted: Fri Feb 27, 2015 10:19 am Post subject: |
71's are a great year for Bay Windows! Upright motor, Disc Brakes, still a low light! I'm currently doing a 71 Deluxe Sunroof and can't wait to get out and drive it! Good Luck with your project!!! _________________ Jason A.
Fresh Air VW Club, Pittsburgh,PA
73 Super Beetle, 71 Deluxe Sunroof Bus |
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Fri Feb 27, 2015 1:01 pm Post subject: |
You're gonna need to replace that bug exhaust with a proper bus exhaust. _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Feb 27, 2015 10:58 pm Post subject: |
Anchovy wrote: |
Sounds like the voice of experience. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
drakonis Samba Member
Joined: June 15, 2012 Posts: 251 Location: Granite Falls, WA
Posted: Fri Feb 27, 2015 11:23 pm Post subject: |
yes. please do. you will thank yourself later. i know i did. lol. _________________ 71 Bay. "ketchikan" |
ajam Samba Member
Posted: Sun Mar 01, 2015 10:00 am Post subject: |
Yeah its a sharp place down there with the motor put for sure |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Mon Mar 02, 2015 11:02 am Post subject: |
I have a tiny scar in my hairline from those screws. I solved it by always wearing a hat. lol.
Nice bus and a great start! I love the colors and interior. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
ajam Samba Member
Posted: Tue Mar 03, 2015 1:21 am Post subject: |
Yeah I picked up a bed a couple weeks ago but i think I'm going to paint the floors first, especially after I deal with that rust in the front. I've seen some people on here do some kind of spray on rubber stuff like 3m undercoating or something similar over some por 15 so I think I might do something like that |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Tue Mar 03, 2015 2:45 am Post subject: |
I'd work on the engine first. But that's just me. As long as you've got good compression, get a good carb and dizzy, then it won't take much to get it running. With a running engine first, you'll have a "rolling resto", meaning you can fix it up as you drive it. I've found that helps tons with the motivation to keep a project going. So many people start fixing up their buses and spending time and/or money on unnecessary things then run out of funds and motivation.
71 deluxes are the best by the way! _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
ajam Samba Member
Posted: Tue Mar 03, 2015 6:24 pm Post subject: |
I've actually already got the motor out and stripped down and I have most of the parts to rebuild it. I'm just waiting on a new oil pump puller to finish tearing it down. I didn't think to loosen the case bolts first and it just bent the puller. Also last night I ordered a dakota digital CHT gauge and a vdo oil pressure, already have oil temp so I'm going to be putting those in sometime soon. |
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Tue Mar 03, 2015 8:09 pm Post subject: |
A little simple green and some scotch bright pads for that engine compartment. Give that new motor a nice nest to live in. _________________ 2001 ZO6 (450+hp)
1985 930 Turbo (400+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
1970 Chimney Pop Top (120 hp) SRFBUS1
1990 Vanagon (95 hp)
1985 Vanagon GL (85 hp)
1969 Tin Top 1 owner OG
Can I get any slower?
2015 CC R-Line (heavily mod'd) |
ajam Samba Member
Posted: Fri Apr 03, 2015 11:40 am Post subject: |
Its been slow but I dropped off my case to have it align bored, still need to rebuild the carb so maybe one more paycheck before I've got the motor built and installed, still need to order a couple things.
I've heard that CHT sender wires shouldn't be placed within a foot of a wire carrying a current and if thats the case I have no idea how to route it where it will be long enough so any ideas on that would be great
Got the engine bay cleaned up
Trannys out so I can replace shift rod bushings and coupler. Theres quite a bit of forward backward play in the hockey stick I don't know how much play can happen before its not good but I did pick up a bushing/seal kit for it
so yeah I just need to put the trans back in , finish wiring up the new guages and build a motor for it then I should be good to go |
Posted: Fri Apr 03, 2015 2:08 pm Post subject: |
Looking good _________________ 2001 ZO6 (450+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
