stressfree Samba Member
Posted: Mon Mar 02, 2015 5:03 am Post subject: Fixing chrome valve covers |
Seems like those chrome covers leak.should I get cork gaskets for the chrome ones or buy the black ones with cork. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Mon Mar 02, 2015 5:48 am Post subject: |
Find good OEM ones in the classifieds and use either cork or rubber. |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Mon Mar 02, 2015 6:54 am Post subject: |
I've had better luck with the cork gaskets. Be sure that the covers are not bent (check them against the head for any play before installing the gasket. Also, you may want to bend the wire bales slightly to get more clamping force, a little goes a long way. You can glue the gasket to the cover with a thin layer of high temp RTV to keep the gasket from slipping out of place when you install the cover. Don't put any on the head side, and let it set up before you install the cover. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Mar 02, 2015 12:20 pm Post subject: |
3M weatherstrip adhesive works very well to hold the gaskets into the covers.
Another good trick is to cut (4) 1" pieces of rubber fuel hose. Install (2) pieces onto each bail (valve cover clip) and position them at the two peaks that apply the main pressure to the covers. This will prevent scratches and slightly increases the clamping force.
I recommend stock bails too. I've had better luck with them in the past. I suspect they may have greater clamping force. Also, be sure to make sure the bail isn't bent and applies even clamping force across the valve cover. I've seen bails that would clamp one end of the cover and barely touch the other end. A little tweeting can easily solve that problem. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
monomanx Samba Member
Joined: September 25, 2004 Posts: 715 Location: Southeast
Posted: Mon Mar 02, 2015 3:41 pm Post subject: |
I use bearing grease to hold the gasket in place on the cover and smear some extra on the face side of the gasket. It seems to work pretty well. I still get drips but I would rather clean up grease than get glue and silicone off of the covers. |
jrailer Samba Member
Posted: Mon Mar 02, 2015 5:32 pm Post subject: |
+1 john its not the covers its the clamps use the stock clamps if you have some |
Posted: Mon Mar 02, 2015 8:21 pm Post subject: |
MonoManx, I assume your motor has never "inhaled" a set of valve cover gaskets? This happens when you have a high performance motor spinning up in the RPM range then suddenly snap the throttle closed. That wound up "air pump" is suddenly looking for air from somewhere and the vacuum in the cylinders will suck right past the rings and send the crank case atmosphere into a vacuum. If the valve cover gaskets are not securely held in place they'll get sucked inwards, usually along the bottom edge. Then you start leaking buckets of oil onto the ground below. _________________ www.LoCashRacing.org
Posted: Mon Mar 02, 2015 8:28 pm Post subject: |
LoCash,
The short answer...no.
Long answer: I mostly run 40 HP and 1600s. My 1776 has bolt on covers and it has not had this problem nor has my 1835 with stock clamp on valve covers.
Since these are mostly in buggies they are easy enough to check and I do that pretty frequently.
I am sure that tacking them in place with 83H or some gasket glue would be best. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Mar 03, 2015 7:52 am Post subject: |
I was under impression for along time that using Aviation #3 gasket sealer was sufficient to hold gaskets in place and after sucking in gasket 2 times in less than a year, I have gone to 3M weather stripping cement (glue) on valve cover side only, will see how good that does...
Also Scat make a pretty nice stainless steel valve cover that has tabs spot welded into it to keep gaskets in place, never had a gasket problem with them on race car....
