redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Mon Mar 02, 2015 4:49 pm Post subject: Chokes on 32 PDST carbs |
Probably a dumb question but should the choke elements on the carbs get warm to the touch. Recently had a short and the chokes dont look to bad. At least the little coily element inside the choke is intact. I know they recieve current from the ignition coil but are they supposed to get "hot". Thanks for any reply s in advance. _________________ Different Strokes for Different Volks
74 Standard Type 1
69 Squareback Type 3
55 Oval Type 1 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Wed Mar 04, 2015 9:12 pm Post subject: |
They are supposed to get warm, but not hot. I ran into one situation where I rebuilt an engine and could not get it to fire. I found that I didn't have spark, and I traced everything down in the ignition, and it all checked out. I was totally exasperated at that point and I was shaking my head and leaned over and put my hand on the carb and it was HOT. It turned out that the choke element had a short in it and was pulling so much current that there was not enough voltage for the ignition to produce spark. So I guess that we each have our own definition of hot, so if the engine still runs fine, it shouldn't be a problem, But if you are having starting issues, disconnect the chokes and try it again. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
