rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Thu Mar 05, 2015 7:59 am Post subject: Distributor reassembly - driving dog |
Hello,
I took apart a 205M distributor and I'm a little confused about the Bentley instructions for reinstalling the driving dog. It says to "install the driving dog so that the lugs are offset towards the mark on the housing". I don't understand what it means by "offset towards the mark on the housing". I assume the "mark" is the notch on the rim of the housing.
Also, I see reference to axial play. What does this refer to?
Thanks for any help. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Thu Mar 05, 2015 8:12 am Post subject: |
The drive can be put on 2 ways, once is correct and the other is 180* off. Since you didn't not the way it was before, i say install it and if the engine doesn't start, rotate it 180*. _________________ Glenn
Member #1009
#BlueSquare |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Thu Mar 05, 2015 8:24 am Post subject: |
50/50 Chance your right !Next time mark it before taking apart! |
Posted: Thu Mar 05, 2015 8:46 am Post subject: |
What do I mark? This is a spare distributor. It has never been in my car.
Thanks. |
Glenn Mr. 010
Posted: Thu Mar 05, 2015 8:47 am Post subject: |
Put a mark on the drive and the shaft. before you take it apart. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Mar 05, 2015 9:08 am Post subject: |
OK....dumb question. I see that the two "teeth" on the dog have an angled surface. Are you saying that if someone were to assemble a distributor from a pile of parts, there is no way to determine the orientation of the dog other than trial and error (i.e. 50/50 chance of getting it right the first time)? What if someone were to install a NOS distributor....would there be the same issue?
Thanks! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Mar 05, 2015 9:29 am Post subject: |
not a dumb question
look at the#1 notch in the cap and how the cogs are and they should be orientated that the fat side is away from the # 1 notch
They are this way on the 3 i quickly checked _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Glenn Mr. 010
Posted: Thu Mar 05, 2015 9:34 am Post subject: |
rcroane wrote: |
Thanks! |
A NOS distributor is already assembled correctly.
60ragtop wrote: |
not a dumb question
look at the#1 notch in the cap and how the cogs are and they should be orientated that the fat side is away from the # 1 notch |
Not all, i've seen some models, mostly Type 3, that are opposite. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Mar 05, 2015 9:35 am Post subject: |
yeah but we are not talking of type 3
general observation since we are in the 58-67 bug forum _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Thu Mar 05, 2015 9:42 am Post subject: |
Ah ha.....I think I see now. I hadn't noticed before that the teeth on the dog are offset to one side. By "fat side", I assume you mean the larger part of the "circle" that the teeth sit on? And if I'm looking at the distributor from the bottom, the fat side should be to the right? This would seem to correspond to what Bentley says about the cogs being offset towards the mark.
Thanks. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu Mar 05, 2015 3:09 pm Post subject: |
Check this picture, and then position your drive dog and distributor shaft so the rotor points to the slot on the body lip, making sure the advance can is located so it clears the fuel pump when installed.
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Thu Mar 05, 2015 3:25 pm Post subject: |
Photo I had in my gallery. I used a spring loaded punch to mark the dist. before disassembly
Posted: Thu Mar 05, 2015 5:58 pm Post subject: |
Sorry guys, but I'm still confused. Looking at the picture from Bentley above would put the dog in a position that the lugs are offset AWAY from the notch on the rim. But, the directions in Bentley for installing the dog say that the lugs should be offset TOWARDS the notch.
What am I missing here?
Sorry to be so dense. |
Posted: Thu Mar 05, 2015 6:23 pm Post subject: |
You can't tell where the # 1 notch is in the above pic.
If it is a spare dist just match it up to what dist is in the car now as it will be going in there ? _________________ Rick
tasb wrote: |
sb001 wrote: |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Mar 05, 2015 10:10 pm Post subject: |
Here's the way I do it. I rest the distributor on my chest with the shaft that the rotor sits on against my shop apron. I line the open notch that the rotor lines up with towards my head. In this position the shims and the drive dog go on and the narrow or short side of the drive dog offset faces my head. I set the pin in finger tight then placing the distributor on my vice I drive the pin the rest of the way home. This would work for the "205 M" assuming its either a 111 905 205 M or a 113 905 205 M. If its one of the other 205 M's that Bosch produced the instructions for installing the drive dog would probably be reversed. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Sat Mar 14, 2015 5:07 pm Post subject: |
rcroane wrote: |
Are you saying that if someone were to assemble a distributor from a pile of parts, there is no way to determine the orientation of the dog other than trial and error (i.e. 50/50 chance of getting it right the first time)? |
I just got a 113 905 205 T and the drive dog, pin and coil spring were not attached. After cleaning it up and reassembling, I noticed this thread.
In this picture, the mark on the case is at 12 O'clock in this picture. Anyone know if this is correct or am I 180* off?
Posted: Sat Mar 14, 2015 7:53 pm Post subject: |
Is your rotor pointing to the #1 mark on the case? If so, I'm pretty sure you are 180 degrees off. I found @tasb's technique above to be the easiest way to get it right. |
Posted: Sun Mar 15, 2015 4:50 am Post subject: |
Thanks. Yes, the rotor is pointing to the mark. I tried tasb's technique too and thought it was 180* off but wanted to check. |
Posted: Sun Mar 15, 2015 8:30 am Post subject: |
Also use the picture posted by KTPhil. Use this to visulize how your distributor will drop down in the hole. The cogs on the drive dog will be parallel to the crank pulley with the smaller side of the dog pointing towards the pulley. You'll see how it goes by looking down in the hole. Remember, turn your crank to #1 firing position before removing the old distributor! |
