67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Mon Mar 09, 2015 11:32 am Post subject: SPI epoxy primer and filler question |
Whole car, doors, hood, decklid, etc was sprayed 2 months ago and is fully cured.
I "believe" I need to scotchbrite red the area to be filled and then use my filler. (Should I call it filler or bondo?)
Anyway, I went by my paint store today and he sold me Evercoat Rage Ultra body filler and said its great stuff.
Am I headed in the right direction?
Stuart Maingot Samba Member
Joined: December 13, 2009 Posts: 240 Location: Trinidad West Indies
Posted: Mon Mar 09, 2015 3:22 pm Post subject: |
I am familiar with 220 grade sandpaper to abrade epoxy for application of filler, build primer, seal coat etc after 24hrs plus cure time have elapsed.
so i would say you are on the right track but not certain of the abrasion of scotchbrite red for this purpose. |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Mon Mar 09, 2015 3:33 pm Post subject: |
You need to seriously scuff before using rage on cured epoxy primer. Scothbrite red pads won't do the trick.
Epoxy primer needs to be filler'd and topcoasted within a short window (2-5 days depending on epoxy brand). Once that window closes, you have to do a lot of prep work before you topcoat epoxy.
Putting filler on scuff sanded cured epoxy doesn't make much sense to me. I would sand to bare metal with 36 grit on a DA sander wherever you are going to apply filler, then apply filler, then sand the remaining cured epoxy with 220 followed by 320 before applying high build primer.
Re-read the manufacturers directions SPI has good info online. It iwll tell you what you need to do. If you are still unsure, contact them for more clarification.
Be careful - you really don't want to do this wrong or it will show up in your final paint job. _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Mon Mar 09, 2015 3:56 pm Post subject: |
from SPI website prior to topcoating with your high build primer:
"This epoxy does not need to be sanded if it’s primed over within 7 days. Always prime over the epoxy within 7 days. After 7 days the epoxy should be sanded with 180 and re-coated with epoxy for best adhesion. " _________________ Wish List:
Mark Laken
Fort Collins, CO |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Mar 10, 2015 4:44 pm Post subject: |
If the filler goes directly on the metal ,there will be no anti-corrosion protection from the primer if it has it.
Unless you need to fill a huge dent ,why not use glazing putty with hardener? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Tue Mar 10, 2015 9:36 pm Post subject: |
Correct, SPI forums say to da lightly with 180 grit to take the shine off but not to bare metal and the apply my filler.
Started on a rear fender today!!! Yeahhhhhh!! Finally the bodywork! Can't wait! |
