snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Sun Feb 22, 2015 8:56 am Post subject: 36hp Lifter Oil Groove ? |
Do you think there is any advantage to grinding a notch between the oil grooves on a 36 hp lifter? I have done this on 1600 lifters. Suppose to be for better oiling. Jim |
slalombuggy Samba Member
Posted: Tue Feb 24, 2015 6:28 pm Post subject: |
Anything you can do to get oil to the top end is good. Did you do the Hoover mod to add an other oil galley going to the right side of the case as well?
brad |
Posted: Wed Feb 25, 2015 7:09 am Post subject: |
slalombuggy wrote: |
brad |
What case oil mod? Now you tell me after I glued it together. thanks Jim |
Posted: Wed Feb 25, 2015 5:16 pm Post subject: |
On my cases I drill the galley plugs out and on the 1/2 side I extend the oil galley fron the center cam journal to the one closest to the gear and then drill down through that bearing saddle to meet up with the extended galley. I don't know if it can be done on a 36 case? Sorry, should have said that in my original post.
EDIT: I just looked in the gallery and the 36 cases are different. But you can do this to your 1600 based cases. It really adds to the oil getting to the top end on that side of the case.
brad |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Fri Feb 27, 2015 3:09 pm Post subject: |
Here's how I modified some lifters--turned about .5mm off the land separating the oil hole from the feed groove, so that the pushrod gets oil all the time instead of only when the valve is open.
Posted: Fri Feb 27, 2015 6:41 pm Post subject: |
You guys and your fancy lathes and skills
brad |
avus Samba Member
Posted: Fri Feb 27, 2015 8:34 pm Post subject: |
brad |
Well, you could chuck it in your Harbor Freight cordless, and chew it down with a rasp, too. |
Posted: Sat Feb 28, 2015 10:02 am Post subject: |
avus wrote: |
brad |
Been there done that.
brad |
Posted: Sat Feb 28, 2015 10:52 am Post subject: lifter |
Well I ground a notch between the 2 grooves. I did notice some thing else. Had to buy a couple of WW lifters to make up a complete set. The grooves on the WW lifters are quite sharp so I stoned the edges off in the lathe. Brad , it`s so nice having my own little machine shop. Jim |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Mar 18, 2015 10:47 am Post subject: |
how much oil flows past the piece of wood in a 36hp pushrod?
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Wed Mar 18, 2015 11:13 am Post subject: |
earthquake wrote: |
Casey |
None........I always pull the chopsticks out. Most all the later style lifters don't have them. As for the cutting between between the spaces, well not all lifters have the two grooves. Some lifters have a single groove which tends to hold more oil. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
mark tucker Samba Member
Posted: Wed Mar 18, 2015 8:12 pm Post subject: |
I would remove the center grove.hmm on second thought,I would remove the high spot between the two grooves and in the prosess lighten the lifter some. and or add a slot to the lifter bore.and enlarge the oil gallys a bit if needed. |
avus Samba Member
Posted: Wed Mar 18, 2015 9:12 pm Post subject: |
mark tucker wrote: |
An issue I can see with sending too much oil up the pushrod is possibly starving the cam bearings. I think the "chopsticks" and the timed grooves on the tappets are meant to limit the amount of oil sent to the top end. The engineers had some reason... |
Posted: Sat Mar 21, 2015 10:12 am Post subject: lifters |
The replacement WW lifters don`t have any wood in them. |
