Udo.B. Samba Member
Joined: May 05, 2005 Posts: 224 Location: Iserlohn/Germany
Posted: Fri Mar 27, 2015 7:53 am Post subject: 70's gearbox |
I bought a 70 beetle and would like to know what Ring and pinion the original gearbox has ? I think they have IRS in the rear also ? I do not have the car here so this is why i ask silly questions
Udo _________________ www.udobeckertuning.de |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Fri Mar 27, 2015 8:28 am Post subject: |
You can find the transmission final drive ratios in the HBB off road section...Look up the "transmissions for Dummies" sticky.....I believe a 1970 Bug w/IRS would be a 4.12 ring and pinion ratio. |
Bruce Samba Member
Posted: Fri Mar 27, 2015 6:15 pm Post subject: |
If your 70 Beetle had a 1200 or 1300cc engine, it would have a 4.37:1 R&P. If it had a 1600, it would have a 4.12 R&P. _________________
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Fri Mar 27, 2015 8:21 pm Post subject: |
I would wait if you are buying parts to confirm anything that might be unkown until you look in there. best indicator of a replacement part is finding the tranny code and checking with a parts supplier. I would avoid rebuilding it yourself it is actually chaeper to buy a rebuilt one moost of the time. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sat Mar 28, 2015 11:49 pm Post subject: |
It was only north America that got IRS in standard beetles, being in Germany it will be swing axle unless it was automatic or been converted and as Bruce said the ring and pinion will depend on what engine it had.
If its 1200 or 1300 (car will drum front brakes) 4.375 or 1500 (disc brakes) is 4.125
Only north America got 1600 beetles in 70 so it wouldn't have been that originally. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Udo.B. Samba Member
Posted: Sun Mar 29, 2015 2:36 am Post subject: |
It is a californian car - i wait until i get it here to look for the code on the gearbox.
thanks for your reply's _________________ www.udobeckertuning.de |
Udo.B. Samba Member
Posted: Mon Mar 30, 2015 12:36 pm Post subject: |
Looks like i had good luck with the car . it has AH engine so 1600 cc and may be a long gearbox
Bruce Samba Member
Posted: Tue Mar 31, 2015 8:50 pm Post subject: |
Joel wrote: |
It was only north America that got IRS in standard beetles, |
And Australia in 1976. I know it's an obscure country, but they got IRS std Beetles with manual gearboxes there. You should visit there and see them at the car shows. _________________
Joel Samba Member
Posted: Wed Apr 01, 2015 12:47 am Post subject: |
Yeah I hear they have good VW shows
I left the Oz 76 out to avoid confusion as not many on here would know about them.
Anyway interesting that someone would go to all the effort of importing a US car to Germany. _________________ Quick little bug, you got a Porsche motor in that?
