Brian Samba Moderator
Posted: Mon Mar 23, 2015 8:10 pm Post subject: |
vwracerdave wrote: |
The only benefit of a stock weight flywheel on any vehicle is for people that are not very good at shifting and driving a clutch car. |
I'd care for further explanation on this. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Mar 23, 2015 8:19 pm Post subject: |
Absolutely Aircooled wrote: |
Found a Bugpack 4062-10 cam in my parts that I didn't know I had. Can anybody comment on how they think this would work in a 1915 with stock heads and any of the carbs setups I mentioned initially? What does super torquer actually mean? I found the quote below from this website.
http://www.lowbugget.com/bugpack_cams.html
4062-10 .425 284º .484/.542 Super Torquer! Our most popular cam sold. Excellent low end and mid range. Moderate idle good up to 6500 rpm.
The .425 is with 1.1's the other ones .484 and 5.42 are with 1.25 and 1.4's respectively. |
It'll be fine. My friend has that "absolute exact "combo in his ghia. 40hpmxs, stock heads, runs great. Real close to a 110 cam. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Mar 23, 2015 8:25 pm Post subject: |
Brian wrote: |
I'd care for further explanation on this. |
Take the time to read what Gene Berg had to say about stock & lightened flywheels. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Mar 23, 2015 8:35 pm Post subject: |
I read the article about the heavier pulley for lightened flywheels on drag applications. I'll read the other ones though.
I don't want to debate on it, just seems that some vehicles would want different weights. But, I don't know. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
modok Samba Member
Posted: Mon Mar 23, 2015 8:46 pm Post subject: |
The middle size bugpack cam is similar to engle 110. |
Absolutely Aircooled Samba Member
Joined: September 22, 2006 Posts: 28 Location: Chico/Paradise, California
Posted: Mon Mar 23, 2015 9:58 pm Post subject: |
Blue69Baja wrote: |
Baja 1914 stock guts. Pict34 carb with mild jet changes.
31's on the rear. 4 gear is lower than stock for to cruise the Hwy with the big tires. Stock flywheel...
Great low end torque. Rarely rev over 3K...
Jim |
Like the Baja. _________________ 64 Bug
65 Kombi camper |
mark tucker Samba Member
Posted: Tue Mar 24, 2015 8:41 am Post subject: |
I had a 1874 in my baja, then a 2332 then a 2028.the 2332 was the best, but I only ran it for 3 years untill I decided it needed a roller cam.....and many projects lator it still isant back in the car. |
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Tue Mar 24, 2015 10:22 am Post subject: |
I just put a 1915 in my baja and love it. But I also have SNPS and spent too much. lol
That means "shiny new parts syndrom".
I have a lightened flywheel. It is a very snappy motor. I'm gonna try a stock weight flywheel next time the motor comes off to see if its reduces that at all. _________________ Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja |
Posted: Sat Mar 28, 2015 7:44 am Post subject: |
Ripped into a single port motor yesterday and found it actually had Mahle 90.5's in it in good shape. I bought this motor thinking it was a 16. Strange that it was a 1776. In any case, I may just go ahead and use those. I am sure some may think that's stupid but so far I have found almost everything I need to build this motor at home. Why not? I don't exactly have tons of money to spend. _________________ 64 Bug
65 Kombi camper |
