sb001 Samba Member
Posted: Sat Mar 28, 2015 12:39 pm Post subject: |
sb001 wrote: |
Cusser wrote: |
Well, I've never done an autostick either. But should be easier. Make note of how your accelerator pedal attaches, take photos, it's not that intuitive, many get it wrong.
Typically, when I've removed the pedal assembly, I've left the brake pushrod attached to the pedals, and just wiggled the assembly out (the brake master cylinder bolts are NOT touched). That rod is just a press fit and you should be able to get a replacement or straighten yours.
The bottom of your pedal doesn't look bent, so that's good. |
So, I think this might be my only option- it looks rather simple to remove the pedal assembly (just the two bolts attaching it to the tunnel?) But I want to make absolutely sure I don't screw up the brake pedal/ master cylinder operation before proceeding, does the cylindrical rubber seal come out with the brake pushrod as well? Or do I just wiggle the pushrod out from that? And, when reinserting, does it just push right back in?
Thanks |
Never mind- got the pedal assembly out exactly as you described. Thanks _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
sb001 Samba Member
Posted: Sat Mar 28, 2015 1:49 pm Post subject: |
Well, figured out the crux of the problem-- my accelerator tension spring is broken on the pin bracket end. That end is completely missing:
It looks like it is supposed to hook over the pin bracket (there's even a little groove in the bracket right where that end of the spring should be) but the spring is toast.
Now, since I have been driving with that spring broken for years, I doubt it makes all that much of a difference--the angle of the accelerator pedal holds it against the roller anyway-- the only real thing the spring does is keep the pedal from being able to spring backwards. I'm not sure if I can get JUST the spring itself- I don't need a whole new assembly just for that.
Anyway I got the pin hammered back through the bracket so that the pedal is now nice and even. Now upon reassembly I have one more quick ??-- what does the other end of the brake pedal spring rest against?? (The end opposite the one that hooks over the brake pedal rod?) Is it just the floor itself? Or does it somehow rest against the stop plate for the brake pedal (which would mean really rotating that end around?) Thx _________________ I'm the humblest guy on this board.
1600 SP engine
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Mar 28, 2015 4:31 pm Post subject: |
I haven't looked in a while, but a few years ago I bought a pedal rebuild kit from Wolfsburg West. It had new spring, pin, roller and maybe some other small bits I can't recall at the moment. And it was really cheap. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 759 Location: Sumter, SC
Posted: Sat Mar 28, 2015 4:48 pm Post subject: |
Q-Dog wrote: |
I haven't looked in a while, but a few years ago I bought a pedal rebuild kit from Wolfsburg West. It had new spring, pin, roller and maybe some other small bits I can't recall at the moment. And it was really cheap. |
They still offer it.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111721615A _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
"It’s better to give than to receive. Especially advice." -Mark Twain |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Sat Mar 28, 2015 10:23 pm Post subject: |
sb001 wrote: |
Anyway I got the pin hammered back through the bracket so that the pedal is now nice and even. Now upon reassembly I have one more quick ??-- what does the other end of the brake pedal spring rest against?? (The end opposite the one that hooks over the brake pedal rod?) Is it just the floor itself? Or does it somehow rest against the stop plate for the brake pedal (which would mean really rotating that end around?) Thx |
This pic comes from that same thread you pointed to above.
You can see the small hook of the spring over the rear (rear of car) facing side of the base.
The longer side of the spring clips into a bracket on the front side of the pedal. You can see the two types of brackets in the pics earlier in the thread.
Installation note: before you slide the pin in, lay the spring in place with the loop up. Look at the pic I posted above. _________________ AshMan40
sb001 Samba Member
Posted: Sat Mar 28, 2015 11:10 pm Post subject: |
thanks ashman -
I was actually wondering about the brake pedal spring, where the longer flat end of it goes- but I found from another thread that it is supposed to rest on the floor pointing toward front of car...? _________________ I'm the humblest guy on this board.
1600 SP engine
