levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Brian Samba Moderator
Posted: Mon Mar 09, 2015 8:09 pm Post subject: |
Bernard, I'm extremely interested in that book. I was thinking of using my extra space behind the engine for a cyclone filter; since trucks don't have the gas tank right there. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Mar 09, 2015 8:29 pm Post subject: |
Brian wrote: |
Bernard, I'm extremely interested in that book. I was thinking of using my extra space behind the engine for a cyclone filter; since trucks don't have the gas tank right there. |
Why not install a second tank? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Lynn Gleason Samba Member
Joined: August 17, 2011 Posts: 109 Location: Port Townsend, WA
Posted: Mon Mar 09, 2015 9:41 pm Post subject: Sahara Handbook |
There exists an excellent book related to this subject, called "Sahara Handbook", by Simon & Jan Glen (published by Roger Lascelles--Cartographic & Travel Publishers). The Australian authors ran tours throughout the Sahara, and their vehicle of choice was the Bay window Westy camper. Chapter 18 "Survey of Potential Vehicles", covers all the vehicles likely to be found in the area, and their respective strengths and weaknesses, paying particular attention to Volkswagen Transporters. They mention the aforementioned pamphlet: "Group Z4: Instructions for Operating Passenger Cars and Transporters in Tropical Climates", as well as, Volkswagen part numbers for essential modifications. To wit:
VW Option M 220--ZF Limited Slip Differential.
VW Option M 153--"Cyclone" Pre-cleaning Air Filter, VW part #029-129-607A
-or- a two stage filter such as: American Donaldson, -or- the French Tecafiltre.
VW Option M 073 Belly Pans, to add torsional strength.
Plus skid plates as outlined in the "Group Z4 pamphlet.
They also go into great detail on:
Engine set-up (compression ratio, dwell angle, valve clearances, etc.)
Suspension set-up (take off your sway bars!)
Load distribution (don`t overload the front of your vehicle!)
Spares--spares--spares--and MORE spares)
Plus a wealth of knowledge on how to handle:
Desert conditions.
Sand, washboards, VERY bad roads, NO roads, etc.
Breakdowns (can be dangerous and/or deadly, in some desert areas--even in the U.S. ie. Death Valley).
Now while you may never travel in such exotic conditions, the techniques for sand travel may keep you from getting stuck (or un-stuck), on some beach somewhere! Good book! Find one!
Lynn Gleason
`98 Golf
`79 AdventureWagen Camper Bus (with LSD)
`69 Porsche 912 Targa |
Tcash Samba Member
Posted: Tue Mar 10, 2015 12:56 pm Post subject: Sahara Handbook |
Purchase mine last night.
Sahara Handbook/ amazon
ZENVWDRIVER
Any change you could scan (VW, Technical Recommendations, Journeys under difficult conditions for the VW Transporter) and email it to Everett?
Thank You
Tcash |
Posted: Fri Mar 13, 2015 8:14 pm Post subject: |
Mocked up the bumper and welded up the brackets to adapt the GoWesty vanagon steel bumper to the bus. The final position I ended up going with is in the second picture below. Tomorrow I'll section out the extra length from each side to snug the ends up next to the bus.
Edit: after sectioning out additional length, adding corner fill plates and a bracket to lock the jack down with.
_________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs
jeronimovw Samba Member
Posted: Sat Mar 28, 2015 11:47 am Post subject: |
Up to sc
Swap TD
rsbadura Samba Member
Joined: November 30, 2009 Posts: 656 Location: Berlin, Germany
ernie norley Samba Member
Joined: September 27, 2009 Posts: 170 Location: nambour australia
Posted: Sat Mar 28, 2015 9:22 pm Post subject: |
G'day all. This where I'm up to on my 4x4 conversion. all the positions are now sorted. Now to build & weld the mountings on to the beam & have the axles modified. I have offset the diff to allow the tailshaft to run beside the sump not under it
ernie
Tcash Samba Member
Posted: Sat Mar 28, 2015 10:38 pm Post subject: |
Thanks for the update.
Tcash |
Tcash Samba Member
Posted: Sat Mar 28, 2015 11:21 pm Post subject: |
Brian wrote: |
rad. Tcash, did you get your sahara book yet? |
Yes I did as a matter of fact. It is a good read. Just haven't picked it up very much.
Tcash |
Posted: Sun Mar 29, 2015 12:04 am Post subject: |
I skimmed through, and it's cool. The Jeff Hibbard's Baja Bug book is a lot more useful though. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
RetroHäschtäk Samba Member
Joined: October 25, 2014 Posts: 7 Location: Deutschland
Posted: Thu Apr 02, 2015 8:53 am Post subject: Gear Rod / Adjusters Problem |
Hey all,
the process with my modifications are on a good way.
but i have a big problem.
The Gear rod get in touch with the adjusters at ther frontbeam.
Must i bend the rod with a larger radius.
What was your solutions ?
Did anybody have a picture of these section, where i can see what right
Hope you can help again
and with best regards from germany
Maarten _________________ ".....roadracing since 1988" |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Thu Apr 02, 2015 10:50 am Post subject: |
I just bought a copy from abebooks.com ... Spent a whole $6 after shipping. Great place to buy books if you dont mind em being used. I buy all my books needed for classes there
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
bulli bulli 33 Samba Member
Joined: January 30, 2010 Posts: 14 Location: Slowenia
Posted: Thu Apr 09, 2015 8:47 am Post subject: |
This is the best topic here for me. I have all my undercarriage done and I was prepared to lover my 70' avendture wagen like I done with all other buses before. After seeing all this cool posts I change my mind and I am gonna get high off the ground. My engine is already done, it's a 1776 with 36 Dellortos, short earybay trans, 15 inch rims. My concern is that with bigger tires I will have a lack of power. What is the limit tire choose for this setup?
Second question, I can get CV joints and transaxles from Porsche 924 or 944, do they have a same lengt like a bus or do I have to make any modification?
