SWF washer bottle
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Wed Aug 06, 2008 12:40 pm    Post subject: SWF washer bottle Reply with quote
would this washer be the correct optional one for a '52?
What is the correct spray jet/nozzle for this?
and was there always only a single jet/nozzle used?
thanks
Lind
Lind is offline
PostPosted: Fri Aug 08, 2008 6:12 pm    Post subject: Reply with quote
the style that you pictured is the later style.
the earlier style has the connections on the backside of the pump and the pump rod sticks out of the dash and is activated by pushing it in.
the later style has the connections at the front of the pump and the pump is activated by pulling it out.
http://www.thesamba.com/vw/archives/lit/52accessories.php
Wanted:
Scotty M
Scotty M is offline
PostPosted: Fri Aug 08, 2008 10:52 pm    Post subject: swf Reply with quote
When you say later style do you have specs. on year change?
janerick3
janerick3 is offline
PostPosted: Sat Aug 09, 2008 6:35 am    Post subject: Reply with quote
The SWF pump assemblies are stamped with a date code.
http://www.thesamba.com/vw/forum/viewtopic.php?t=279505
Thanks,
Jan K.
Lind
Lind is offline
PostPosted: Sat Aug 09, 2008 7:04 am    Post subject: Re: swf Reply with quote
I have an earlier style with the code AJ (jan '57) and later style which has the code JH (oct '56) I have a couple others which I need to clean up to read the date codes. those dates do not line up with the literature that I have seen. the '52 literature shows the earlier style, and I have a couple pieces of literature from the '60s that show the later style. IN2VWS might have some input on this also, as he has quite a bit of literature that might have reference to these pumps.
I have seen dozens of the later style, but the only earlier style one that I have seen is the one that I pulled out of a '56 beetle. the later pumps are relatively easy to find. unfortunately there is an obvious difference between the two when they are installed into a car.
Wanted:
Scotty M
Scotty M is offline
PostPosted: Sat Aug 09, 2008 10:33 am    Post subject: swf Reply with quote
thanks for all the info. its kinda wierd that there could be a 56 with a pull type and a 57 with a push type is there any reason to why this is?
Lowdown Dirty Rat
PostPosted: Sat Aug 09, 2008 11:45 am    Post subject: Reply with quote
cheers,
could you post a picture of the early type one you have, especially the jet ends.
thanks
IN2VWS
IN2VWS is offline
PostPosted: Mon Aug 18, 2008 3:30 pm    Post subject: Reply with quote
You could get them with push, pull, foot and electric pumps.
as can be seen here in a '54 catalog
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
Lowdown Dirty Rat
PostPosted: Tue Aug 19, 2008 10:07 am    Post subject: Reply with quote
and the '52 catalog has two jets and the '54 one. But i would think that wasnt a change but another choice?
686 bus-boy
686 bus-boy is offline
PostPosted: Thu Jun 11, 2009 1:57 pm    Post subject: Reply with quote
Can anyone tell me where abouts to find the date code or tell me the years this was made-it is a push pump.Thanks.
jimmy1
jimmy1 is offline
PostPosted: Thu Jun 11, 2009 2:38 pm    Post subject: Reply with quote
cool topic,
i have all the same set up, except for the glass cansiter. Mine has rubber/plastic bag, wonder where do the bag go on?
North Hollywood, CA
1956 Kabrolett
"I'd rather be driving my VW thinking about God than sitting in church thinking about my VW."
check out my classified ads, lots of rare parts/accessories for sale.
tomas persson
tomas persson is offline
PostPosted: Mon Jun 15, 2009 12:51 pm    Post subject: Reply with quote
I have the glass jar for you... and I dont have the rest.
cj1971
cj1971 is offline
PostPosted: Sat Sep 12, 2009 7:48 am    Post subject: SWF Accessory Washer Bottle Kit Reply with quote
Does anyone know where the date code is on the pump please????
habitnz
habitnz is offline
PostPosted: Sun Jun 12, 2011 2:53 pm    Post subject: Reply with quote
I have one of these unit's in a 57 Kombi I was given, where these installed in kombi's originally? seem's like they were in the beetle but cant see and having being installed in busses, mine is complete apart from the front knob is missing, so if anyone has one would be interested.
The bottle to mine was just sitting on the cab floor.
I am going to remove the unit today and cleat up so will post some pics up later.
Rag53
Rag53 is offline
PostPosted: Wed Mar 11, 2015 5:22 pm    Post subject: Reply with quote
Does anyone have a full kit NOS swf washer kit Split oval.
tisius
tisius is offline
PostPosted: Tue Mar 31, 2015 3:56 am    Post subject: Reply with quote
NOS washer kit???
I would give you little chance to locate an unused one straight out of the factory wrapper. These were sold to be built into cars, so I assume shelf life for complete units outside of the SWF factory must have been short.
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
