renka Samba Member
Joined: September 23, 2010 Posts: 36 Location: Holland
Posted: Tue Mar 31, 2015 1:33 pm Post subject: Air filter bracket '63 double cab refitting |
After hours of searching these pages I found one pic of a lefthand fitted bracket to mount the filterelbow to.
Can anyone help me with measurements to refit the bracket at the correct position please
Thanks in advance
Cheers René _________________ to finish first, you first have to finish |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Wed Apr 01, 2015 9:05 am Post subject: |
If you're running a stock-ish engine, you might consider going with a slightly earlier style air filter which mounts on the fanshroud instead of the roof of the engine compartment.
I put these in all my buses, just simpler to install and remove.
Its a type 261 air cleaner, stamped on the upper round air housing.
Some have a 261 part number, some a 211.
Example:
See this thread for info:
http://www.thesamba.com/vw/forum/viewtopic.php?t=289385&start=0 _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
renka Samba Member
Posted: Sat Apr 04, 2015 12:52 am Post subject: |
Thanks guys for the replies, to be sure I will fit the trans and engine in to determine the exact location but your answers helped for sure! _________________ to finish first, you first have to finish |
