life long VW Samba Member
Posted: Thu Apr 16, 2015 12:50 pm Post subject: |
marked for future reference. Thanks for the comparison. _________________ in order
55 sunroof / sema bug
60 23 wndo deluxe safari microbus https://youtu.be/anajRR57nPI
66 21 wndo deluxe microbus
59 bug
63 kombi w/ SO-22 westy
66 squareback
59 logoed standard bus Orangevale Baptist Church
58 PG/SG sunroof /safari standard
94 golf
2013 Bettle TDI (cheater) |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Thu Apr 16, 2015 5:15 pm Post subject: |
OB Bus wrote: |
pyrO's master cylinder might have been for a 68-70? I'd have to crawl under both buses to compare. |
yep, early bay. |
perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Mon Apr 20, 2015 1:22 am Post subject: |
in the same boat.
just bought a '67 bus ATE MC
really, I wont put my safety on cheap labor having an original german part at $150 |
Posted: Mon Apr 20, 2015 10:04 am Post subject: |
perello wrote: |
in the same boat.
where did you find it for $150? |
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Mon Apr 20, 2015 4:29 pm Post subject: |
I found them for 124 Euro but the shipping was really expensive. Search by the UPC # on google. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Fri May 01, 2015 3:52 pm Post subject: |
EIS has the Chinese master cylinders for $50 and the reservoirs for about $28. Ordered them yesterday and they were on the porch today. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Sun May 03, 2015 5:32 pm Post subject: |
I'm probably going to order a Chinese one after this, thanks! This would work for a 63 I am going to convert to dual master cylinder right? |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Thu Sep 15, 2016 1:53 pm Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
Has anyone switched from an ATE dual circuit with spacer to a 67 bus master cylinder? How do they compare?
I am looking to improve the brakes on my 63 and am wondering if the 67 type would work "better" than the current dual ATE that is in the bus. Drums freshly turned on all 4 corners, new brake shoes, fresh fluid and push rod properly adjusted. Stock bus front, 67 beetle rear (straight axled) and it takes a good bit of leg to stop, a lot of leg to get them to lock up. _________________ Paulie
63 Standard OG paint
Last edited by dirtylawnchair on Fri Sep 16, 2016 5:53 am; edited 1 time in total |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Sep 15, 2016 2:34 pm Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
Keep adjusting the shoes till they wear into the drums. Pretty sure rear type 1 drums have a lot less shoe to drum surface area... _________________ In Stereo, Where Available! |
Posted: Fri Sep 16, 2016 5:52 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
Eric&Barb wrote: |
Keep adjusting the shoes till they wear into the drums. Pretty sure rear type 1 drums have a lot less shoe to drum surface area... |
I've been driving it for years like this and recently redid the entire brake system because they did not feel real "strong" (if that makes sense). I guess its time to use the search button about the best wide5 disc conversion for a type2.
So, the answer to my original question is; the 67 style master cylinder will be no better?
My daily is a Golf R....so my brakes are probably fine in the bus. I just get used to the amazing stopping power of the R.. _________________ Paulie
63 Standard OG paint |
sled Samba Member
Posted: Fri Sep 16, 2016 7:30 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
what dual circuit master do you have now? they have different bore diameters which can affect pedal feel.
also, while new shoes and freshly turned drums are a good thing, you are using a small portion of your shoes braking capability when you dont have the shoes arc'd to the drums. Find someone who can arc your shoes and I bet you will see a drastic improvement.
if you go discs, just get 944 rotors and wilwood calipers or wageswest's bustang kit if you want wide 5. _________________ drive your split. |
Posted: Fri Sep 16, 2016 7:44 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
sled wrote: |
if you go discs, just get 944 rotors and wilwood calipers or wageswest's bustang kit if you want wide 5. |
I am running at 71-79 bay bus ATE brand master with aluminum spacer.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C24-211-611-021-AAGR
I tryed to ark them myself ... maybe I should find someone who knows how to get it done properly.
Bustangs look great for stock wheels.
And they should work with my SA Sprints.
"This Bustang disk brake kit will fit under most any aftermarket aluminum or steel 15+ inch wheels."
In the Babystang thread, people are commenting on how the 67 style master requires less leg. I may get one to try...cant make it worse.
http://www.thesamba.com/vw/forum/viewtopic.php?t=537739&start=60 _________________ Paulie
Posted: Fri Sep 16, 2016 7:59 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
dirtylawnchair wrote: |
I tryed to ark them myself ... maybe I should find someone who knows how to get it done properly. |
They will arc themselves to each drum if you drive it and over the next few weeks adjust the brake adjusters two or three times. _________________ In Stereo, Where Available! |
Posted: Fri Sep 16, 2016 8:09 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
Eric&Barb wrote: |
They will arc themselves to each drum if you drive it and over the next few weeks adjust the brake adjusters two or three times. |
Its been several months since the redo. Its mainly a weekend driver but I have a few good cruises since then.
I'll get it up on the lift, tear it down and see if I see anything obvious. Maybe another set of eyes too.
My original question for this thread was; Is the 67 style dual circuit master cylinder a "better" master cylinder over the 71-79 ATE dual circuit with adapter on a bus with drums? My assumption is yes, but wanted to have an Sambaspert shed some light as to why or why not. _________________ Paulie
Posted: Fri Sep 16, 2016 8:18 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
My original question for this thread was; Is the 67 style dual circuit master cylinder a "better" master cylinder over the 71-79 ATE dual circuit with adapter on a bus with drums? My assumption is yes, but wanted to have an Sambaspert shed some light as to why or why not. |
Have been told it is somewhere around 7 to 15% easier foot pressure to put same pressure on the shoes. So not a huge change. Having the shoes adjusted and worn into the drums will make a lot more difference in stopping power. Can lock the brakes up on our 1960 panel walk thru camper conversion with the 1971-79 MC. _________________ In Stereo, Where Available! |
ozinbc Samba Member
Posted: Fri Jan 15, 2021 12:08 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
apologies for re-visiting an old thread- but I wonder what the stop screw in the original master does , and what issues could occur if it is missing? Is it critical for the "dual" function to be effective? _________________ the invisible and the non existent look very much alike |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
Posted: Fri Jan 15, 2021 2:00 am Post subject: |
pyrOman wrote: |
Transporter wrote: |
Pyro, that's not a 67 bus master cylinder. The only ones I've seen as a 67 bus 'specialist' is the type pictured at the beginning of this thread. The brake lines all enter at the same planar angle which is parallel to the road. And the cylinder bore is 22. |
I now wonder how would have it worked?!? As a "gift" I was just about to install it when I realized it was too damn long to fit!
That's why you see the hacked in bug master with the cheesy caps on it now. Yes, I still have to "fix" that but it is definitely braking a lot easyer with it than with the phatchick booster type master it had before! |
That's physics at work for you. You have a smaller diameter piston. It will need more travel to move the same volume as the 22mm piston, but it builds higher pressure with the same force on the pedal. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Fri Jan 15, 2021 8:48 am Post subject: |
mdege wrote: |
pyrOman wrote: |
That's physics at work for you. You have a smaller diameter piston. It will need more travel to move the same volume as the 22mm piston, but it builds higher pressure with the same force on the pedal. |
Very old post there ^^^! That issue was rectified quite some time ago. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Fri Jan 15, 2021 11:42 am Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
ozinbc wrote: |
apologies for re-visiting an old thread- but I wonder what the stop screw in the original master does , and what issues could occur if it is missing? Is it critical for the "dual" function to be effective? |
Keeps the piston farthest away from the pedal push rod from sliding too far toward the push rod.
From 1968-70 bus MC:
Without bolt you have a hole, that fluid likes to spray out of. Plus the piston seals end up in the wrong place possibly causing blockage of passages from fluid flow needed. _________________ In Stereo, Where Available! |
ozinbc Samba Member
Posted: Fri Jan 15, 2021 2:18 pm Post subject: Re: 67 Dual Circuit Master Cylinder Comparison with pictures |
I try not to be a pedant- but the question relates to the fact that the screw (and the hole) is missing in the repro versions of the 67 dual master. Should those installing the repro versions be worried that the function of the cylinder is somehow compromised when a circuit fails? _________________ the invisible and the non existent look very much alike |
