Merian Samba Member
Posted: Fri Apr 17, 2015 4:36 pm Post subject: What is this smaller red wire on the battery? |
1986 Westy - something added for the camper equipment? |
madspaniard Samba Member
Posted: Fri Apr 17, 2015 4:58 pm Post subject: |
that wire powers the flux capacitator _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
johnbyrdgates Samba Member
Joined: August 24, 2011 Posts: 102 Location: Rockport, MA
Im guessing that that is your (possibly modified) ignition/starter exciter wire. On my '87 Westy, there are two wires there. _________________ 1987 2.1L 2WD Full Camper Kerouac |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Fri Apr 17, 2015 5:02 pm Post subject: |
That looks like the main power wire to the dash fuse/relay panel. In 86+ vans without factory AC that wire would be for EVERYTHING except the fuel injection power.
Mark |
Merian Samba Member
Posted: Fri Apr 17, 2015 5:24 pm Post subject: |
Thx, so it runs everything on the Van except the starter & FI injectors (including the ECU).
I have no A/C.
It is the wierdo early 1986 model with NO correct wiring diagram. |
Posted: Fri Apr 17, 2015 5:33 pm Post subject: |
It runs everything in the dash. In the engine compartment it runs the ignition coil and a few light loads. Except in early 86 vans you never quite know without checking. The general FI system gets battery power over the huge cable via the starter.
Mark
Merian wrote: |
I have no A/C.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
insyncro Banned
Posted: Sat Apr 18, 2015 6:13 am Post subject: |
Merian wrote: |
I have no A/C.
I have an 86 "plain jane" as well.
No PS
No AC
manual everything.
A treat to work on except that the FI wiring is as you say, not covered in the manuals.
I yanked all of the FI wires and replaced with a late model harness and all D series components.
She is a runner Bobby, light weight, uncomplicated, a treat to drive. |
Merian Samba Member
Posted: Sat Apr 18, 2015 10:36 am Post subject: |
well, mine has P/S and an A/T; full Westy not a Weekender
yes, That's it. One wire.
I'll post part of the VIN (pm me if you want the full VIN):
GH 025 811 - early ’86; manf. date 10/85 on door post
if VW shuts down in August and reopens in mid- to late Sept. like Porsche does (or did), then this must a really early '86 |
Merian Samba Member
Posted: Sat Apr 18, 2015 10:39 am Post subject: |
BTW, my plan is to add an "inlet" wire for a battery maintainer which is why I had stuff apart
I drilled a hole in the rear face of the battery box and was able to do it with the battery in place - but if anyone sees this and plans to do that in the future, it may well be easier to pull the battery. |
