anty71 Samba Member
Posted: Tue Apr 14, 2015 6:19 am Post subject: 56 splitcase gearbox question. |
Hi,
I’m building up a 56 box, do these boxes use a plastic daisy bushing between the box itself and the axle tube.
I have a later splitcase box (59 I think) and it has them, but they don’t fit the 56 box, they're a bit big?
thanks for your help |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Tue Apr 14, 2015 7:44 am Post subject: |
I'm working on a '56 splitcase also and it doesn't have them either.
I read somewhere on the samba in which year they were introduced but I can't remember the year. _________________ My 1958 PGSG project topic |
anty71 Samba Member
Posted: Tue Apr 14, 2015 7:54 am Post subject: |
Thanks for your replay, yeah I’ve read that they weren’t originally fitted but could be retrofitted.
I don’t think there are different sizes of them?
Have you refitted yours without them? |
anty71 Samba Member
Posted: Tue Apr 14, 2015 8:08 am Post subject: |
Thanks for the link mate.
The plastic daisy that fits my 59 split case doesn’t fit the 56,
So the question is, is there different sizes, or do these early trans not use them and we should just shim them out with the paper gaskets? |
Posted: Tue Apr 14, 2015 8:11 am Post subject: |
This is where I'm at now
This evening I'll check out the condition of the bearings and continue the dismantling.
First time I opened up a gearbox, so I'm still learning _________________ My 1958 PGSG project topic |
Posted: Tue Apr 14, 2015 8:20 am Post subject: |
I don't know how good your German language is, but I've found this site once:
http://www.dj-viela.de/dj-viela_kaefer-b-log/dj-vi...chron.html
In the text under the picture of the plastic daisy, the guy says about later type splitcase gearboxes with the plastic daisy (oct'58 and up?) "Die Kalotten des Gehäuses sind zu diesem Zweck um 1 mm tiefer gesenkt" which means something like "The domes of the (gearbox) housing are 1 mm lower for this purpose"
So I guess if you want to use the domes on an early splitcase, you have to shim the axle tubes 1 mm (on top of the normal shimming). _________________ My 1958 PGSG project topic |
anty71 Samba Member
Posted: Tue Apr 14, 2015 8:27 am Post subject: |
same as that
I'm buttoned up again now and ready to put the tubes back on.
Just spoke to Cogbox here in the UK.
says that some did and some didn't use them, he would of thought that a 56 would but as the daisy of the 59 didn't fit, I shouldn't need to run them.
so, no bush, just pack them out with paper gaskets |
anty71 Samba Member
Posted: Tue Apr 14, 2015 8:36 am Post subject: |
interesting link thanks.
I guess will try bolting them up without and see how I get on then
as that seems to be factory |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Tue Apr 14, 2015 2:42 pm Post subject: |
I don't recall any of the split case boxes using the plastic flower. _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
anty71 Samba Member
Posted: Wed Apr 15, 2015 6:28 am Post subject: |
OK thanks, makes me breathe a bit easier bolting the tubes back up.
Just didn't want get the whole thing built up and find out I have pull the trans out again.
Thanks for your help |
Dave Byron Samba Member
Joined: June 04, 2012 Posts: 184 Location: Grays Essex UK
Posted: Thu Apr 16, 2015 10:09 am Post subject: |
No the early boxes don't use them. As you say you just shim the tubes with the gaskets. Just did our 57 split case box and no plastic daisy's |
Posted: Fri Apr 17, 2015 5:39 am Post subject: |
Did you guys have to replace a lot of internal parts?
I'm trying to source parts now, but it's not easy. You got some tips you could share _________________ My 1958 PGSG project topic |
Bruce Samba Member
Posted: Fri Apr 17, 2015 8:39 pm Post subject: |
Samba ads.
Nothing is repro'd for split case gearboxes, so it's either good used or NOS. _________________
anty71 Samba Member
Posted: Sat Apr 18, 2015 10:22 am Post subject: |
I was lucky my box had reportedly only done 25k and when I opened it I believed him.
It was mint, so just had to button it back up. |
Posted: Sun Apr 19, 2015 12:25 pm Post subject: |
Bruce wrote: |
Samba ads.
Nothing is repro'd for split case gearboxes, so it's either good used or NOS. |
Thanks Bruce, I have noticed the samba classifieds is a great place to source for parts. Maybe in the future companies will start reproducing parts. I think there is some market potential in that.
anty71 wrote: |
Damn you're lucky
My bearings and the first gear teeth are pretty worn on mine. _________________ My 1958 PGSG project topic |
