lemonlib Samba Member
Joined: November 15, 2010 Posts: 196 Location: Inland Empire
Posted: Thu Mar 10, 2011 12:30 pm Post subject: judson magneto |
i found a NOS judson Magneto..i am still messing with my judson super charger...so far i can get the car to start but it seems very hard starting ...it may be the idle circuit on the rebuilt carb is not working..
from what i gather this is a 6 volt coil? is this is why they are asking for you to put a resistor before it.. ? am i better off sticking to my current coil?
i have a 12v 57 car... i have converted everything including the flywheel and the starter.
my question is..if i remove by (blue 12v bosh coil) and put in this judson one , Will i need a resistor? what kind? where do i find one?
thanks
Lemon |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Fri Mar 11, 2011 1:35 am Post subject: Re: judson magneto |
lemonlib wrote: |
thanks
Lemon |
Judson Magnetos are the same for 6v or 12v...for the 12v a resistor is required:
http://vwjudsonregister.tripod.com/magneto_installation_page.htm
The blue coil will work just as well...depends if you prefer the look of the Judson. Not sure of the spec on the modern equivalent ballast resistor listed in the instructions but I'm sure a current 12v Judson Magneto user will chime in. _________________ John.
Posted: Fri Mar 11, 2011 3:06 pm Post subject: |
I went to pep boys they did not have it but napa found something that the same ohm'age.....now it's the relay part ..it says to use a six volt relay..I wonder why? Does anybody know to hook the relay .. the diagram on the original judson magneto is not to detailed....the Judson instruction is kinda strange..to say the least.. |
Simon uk Samba Member
Posted: Wed Apr 06, 2011 2:41 am Post subject: |
did you ever sort this - I took mine magneto off when I went to 12 volts, but it sure did look trick! |
Posted: Wed Apr 06, 2011 5:59 am Post subject: |
Not yet...I have an oil leak on the cooling okrasa coil I am trying to sort out first...this Judson is a bigger job than I thought. |
dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Wed Apr 06, 2011 10:08 pm Post subject: magneto |
I had a problem recently when fitting a judson. I also had problems starting, thinking all the time it was the judson. After some time it turned out to be the starter motor bush badly worn. When I replaced this the car started first time & the judson worked fine without problems. I also have a magneto fitted
dave |
BUGBOY1976 Samba Member
Joined: August 21, 2004 Posts: 278 Location: Australia
Posted: Tue Feb 07, 2012 4:09 am Post subject: |
Can anyone tell me what ohms the resistor is.
I can't find the details on the delco resistor. I'm running 12 volt but wish to run the judson coil so any info would be great.
ok had a bit of luck with searching and found some more info. Not 100% its correct.
•Group Number: 2.173 - Resistor, Ignition Coil
•Part Number: 1957154 - Primary (Blue Stripe) (1.8 OHMS)
•Delco Remy Number: D-1110 |
vdubjim Samba Member
Posted: Sun Apr 19, 2015 6:09 pm Post subject: |
i ohmed this NOS NOS resistor at 1.6-1.8.
also here is the NOS relay.
