mrmojorisin Samba Member
Posted: Thu Apr 16, 2015 12:03 pm Post subject: Part Identification needed Help |
Hi,
I need help identifying the following part, it looks like some kind of fuse terminal that hangs down by the fan shroud by the battery. It looks like the wires feed into the generator although hard to tell.
Its the small black box I'm looking at.
A couple of the connections are broken and I'm hoping it's the reason my car won't start.
Any help ipwould be greatly appreciated as its driving me nuts.
Thanks
Grant
c21darrel Samba Member
Posted: Thu Apr 16, 2015 1:19 pm Post subject: |
Thanks but I'm trying to ID the part, someone on another forum suggested it may be a suppressor for an old AM radio.
The starter motor works, turns over the engine, ive checked the spark plugs, put in a new distributor cap and rotar arm. The fuel seems to be getting to carb.
The car has started although the winter and ticked over just fine, but now turns over but doesn't fire.
Running out of ideas.
Grant |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Thu Apr 16, 2015 1:57 pm Post subject: |
automatic shut-off solenoid on the carb working correctly? |
Posted: Fri Apr 17, 2015 1:28 am Post subject: |
Hello,
Its a 1960 KG originally export to South Africa.
I've looked at the wiring diagram and I cant see anything that looks like this terminal, it maybe a red herring and not related to my problem but I wanted to understand what it was so I could discount it.
Thanks,
Grant |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Fri Apr 17, 2015 12:41 pm Post subject: |
It looks like a plug for trailer lights to me. my grandfather rigged up lights for his beetle years ago, but I dont see that as useful on a ghia. LOL do you happen to have a tow package?
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Sun Apr 19, 2015 1:53 pm Post subject: |
OK had some time to look at the wiring, and there has been some kind of Voodoo in the past, the whole thing makes no sense to me, and doesn't resemble the wiring diagram. The wiring to the coil went through the relay terminal and has come loose hence no spark. I think I'm going to have to unravel it and try to do a limited rewire.
Posted: Thu Apr 23, 2015 5:00 am Post subject: |
OK after spending a couple of days trawling the internet, I believe its an adaptation of a Hard Start relay.
The relay switching the power to the coil, Distributor etc using a wire run from the ignition switch.
The relay looks knackered, any ideas where I can get another, or if there is a modern alternative I can use - I'm in the UK.
If anybody has one wired any pointers would be greatly appreciated.
I have a 1960 KG, with original 1200 engine but looks to have a later regulator.
Thanks for your help,
Grant |
