partwerks Samba Member
Joined: March 27, 2007 Posts: 160 Location: Grand Island, NE
Posted: Sun Apr 19, 2015 1:17 pm Post subject: Drive line |
On a 1996 VW Jetta, with 175,000 miles.
The trans was rebuilt about 3 years ago, and so I wouldn't think that would be the issue, but have never put in CV joints or anything, but seems like there is some slop, that when putting it in gear, and then when stepping on the pedal, there is some feeling of slop, till it takes root.
I shut it off, and put in all gears, and rocked the car back and forth to see how much the car would roll. It almost seems like it should be tighter? As I went up in gears, it rolled back and forth more. Seems like something is getting a bit sloppy.
Any, thoughts, ideas, or suggestions, on what it could be? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Apr 19, 2015 9:13 pm Post subject: |
Automatic? They are like that. Go find another one and compare. |
Posted: Sun Apr 19, 2015 9:49 pm Post subject: |
5 speed stick. |
ps2375 Samba Member
Posted: Mon Apr 20, 2015 4:05 pm Post subject: |
Could be a bad motor mount. If you set the parking brake( or chalk the wheels) and with the hood up(so you can see the motor) put it in gear and try to move the car, if the motor rises up more than a couple of inches, you have a bad mount. That could be what you are feeling. When I replaced mounts in our Golf it made a huge difference. I'd stick with stock, especially on the tranny mount, as that one will transfer a bunch of motor vibration to the dash. |
Posted: Mon Apr 20, 2015 7:22 pm Post subject: |
I'll check it out. |
Posted: Tue Apr 21, 2015 5:15 pm Post subject: |
I tried that, and from what I could see over the dash, I don't think the engine moved more than 3/4".
Mechanic is going to get it up on the hoist over the weekend to check it out further. |
ps2375 Samba Member
Posted: Tue Apr 21, 2015 9:30 pm Post subject: |
If those are good, and the CV's are not clicking, I'd not worry about it. A manual tranny will have "slop" due to gear lash and the CV's will have some also and since you have to account for a CV at each end of axle and the tranny's gear lash, things will "seem" loose. |
Posted: Sat Apr 25, 2015 2:17 pm Post subject: Motor mount replacement |
Sounds like I am going to have to replace the motor mounts, after 175,000 miles.
According to the mechanic, there are 3 of them, but I forgot to ask their names, but from some research, would they be, the rear left, rear right, and front?
I also see there is something called Bushing, front engine subframe, but he did not mention anything about replacing those, but would it be a good idea as well? |
