SoldierBoy18 Samba Member
Posted: Thu Apr 23, 2015 9:32 pm Post subject: 34 pict 3 |
Ok im so how would you say pissed at this 34pict 3 carb .I have cleaned it twice float is fine jets are clean everything seems to be fine carb is only a year old .But here is my problem it idles only when cold but engine will die if you dont give it some gas i have to keep pulling the throttle down and giving it gas to keep running and its really pissing me off.I looked how to tune it on wiki and on youtube did what everyone has told me but it will not idle
Posted: Fri Apr 24, 2015 1:16 am Post subject: |
i have cleaned the inside of the carb twice it is a 1 year old carb it should be running fine.But no matter what i do it will not idle i can make it fast idle for 30 seconds longer but it still dies . |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Fri Apr 24, 2015 11:47 am Post subject: |
Could i be having this problem if the carb is to small for the engine.We have not checked what size the engine is yet the guy who bought the carb thought it was a 1600 so he bought a carb for it for a 1600 .Now all i have to do is find the size of the engine .A friend compared his manx with an 1835 to mine and the case bolts on mine are 5/8 same as his and with a 1600 the case bolts are 9/16 does that change anything? |
Posted: Fri Apr 24, 2015 12:26 pm Post subject: |
I wish I could help but I'm not mechanically inclined. If you don't get an answer here, post your question under the year VW that you have. |
c21darrel Samba Member
Posted: Fri Apr 24, 2015 3:23 pm Post subject: |
c21darrel wrote: |
there is no way of KNOWING what size the motor is unless you pull a head. Gotta know Bore and Stroke. |
its a 1600 pulled it apart its 85.5mm pistons i also valve lapped it while i was inside the engine it was kinda cruddy around the valves.going to set all the valve to .006 |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Fri Apr 24, 2015 4:18 pm Post subject: |
You check the manifold boots for cracks? Sounds like a vacuum leak to me. _________________ HBB took me to BBV. |
Posted: Fri Apr 24, 2015 4:21 pm Post subject: |
enjoyther1de wrote: |
You check the manifold boots for cracks? Sounds like a vacuum leak to me. |
No cracks in the manifold but the rubber covers that go over the manifold and clamp down are worn out. |
Posted: Fri Apr 24, 2015 4:25 pm Post subject: |
Wrap them the best you can (by them I mean the rubber boots) in tape or plastic or some thing to seal the boots and see how she runs. You just want to eliminate possibilitys of a vacuum leak one by one. _________________ HBB took me to BBV. |
Posted: Fri Apr 24, 2015 4:27 pm Post subject: |
Wrap them the best you can (by them I mean the rubber boots) in tape or plastic or some thing to seal the boots and see how she runs. You just want to eliminate possibilitys of a vacuum leak one by one. |
I also found that the gas line was pinched and the valve was not all the way open. I will wrap them as best i can i have E6000 industrial rubberized glue i can fill in any cracks 6000 psi of pressure to break |
Posted: Fri Apr 24, 2015 5:13 pm Post subject: |
Try that. Let us know what you find. My bets on a vacuum leak _________________ HBB took me to BBV. |
Posted: Fri Apr 24, 2015 5:14 pm Post subject: |
SoldierBoy18 wrote: |
A pinched fuel line definitely does not help. _________________ HBB took me to BBV. |
Posted: Fri Apr 24, 2015 5:28 pm Post subject: |
A pinched fuel line definitely does not help. |
I hate thoughs times when it could be a multitude of things like in this case im not sure how good the fuel filter is the fuel line was pinched the valve was not open vacuum could be off.Now i have to re set the damn valve lash on this and i have no clue because im used to go kart engines not car motors my go kart engines only have two valves that are not connected. Can anyone tell me what i should be doing im on the left side of the engine what is valve one vale two valve three and 4 is it the valve closest to the driver being number 1 ? Should i be at TDC when i set valves one and 2 or BDC .I read someone mentioned model of the engine this engine is a UO model |
IFVandal Samba Member
Joined: March 30, 2014 Posts: 140 Location: Meridian, ID
Posted: Fri Apr 24, 2015 11:09 pm Post subject: |
Idle Cutoff Valve on the carb hooked up/functioning? Mine was not hooked up and would only idle stay running when cold. |
