DWP Samba Member
Posted: Tue Apr 28, 2015 4:51 am Post subject: Help with shifter purchase. |
Need recomendations for a shifter that is bent back about 4"-6". from stock for my Baja. After mounting the seats further back it's hard to reach 1st and 3rd.
I am thinking about the Scat Dragfast for early bugs.
DWP |
Brian Samba Moderator
Posted: Tue Apr 28, 2015 8:42 am Post subject: |
Stock 67 down shifters have that bend to them, not sure how much. Hurst and EMPI knock offs are pretty nice too. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
DWP Samba Member
Posted: Tue Apr 28, 2015 9:00 am Post subject: |
Thanks, i will look at them. I was considering the bugpac shiftright but was told it only bends back about 2".
In the photo below you can see how i raised the shift plate and brake plate. The body has a 3" lift and 3 rib trans.After mounting the seats i realized i should of moved the shifter back.
Anybody know how far back the Early Scat handle is bent?
DWP
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2616 Location: West Coast (Michigan's)
DWP Samba Member
Posted: Tue Apr 28, 2015 12:12 pm Post subject: |
Yes I was having a little fun with design. The shift rod itself runs inside the steering part and out the back and to the trans. I have to stop looking at Steampunk sites!!!!!!!
DWP |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Tue Apr 28, 2015 12:29 pm Post subject: |
Hell yes! For steampunk. _________________ rant _ classified ads with out pics are almost worthless |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Tue Apr 28, 2015 1:54 pm Post subject: |
whack the shift lever off and weld whatever you want that fits. |
mtnroads Samba Member
Joined: December 06, 2006 Posts: 403 Location: Minkler, CA
Posted: Sun May 03, 2015 11:58 am Post subject: |
You can always get a bus shifter bend and cut as necessary. I've seen it done in rat rods. _________________ pax
No Good Deed Goes Unpunished.... |
