seans67 Samba Member
Joined: October 06, 2004 Posts: 453 Location: End of the Road, Alaska
Posted: Sun Apr 10, 2005 10:29 am Post subject: Pushrod tubes |
Building my engine back up and I ordered some new pushrod tubes and the are a little longer than the old ones.
Do they compress when you tighten the heads down?
They should be the same for all stock 1600 engines right? Not type 3 specific. _________________ Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Apr 10, 2005 10:39 am Post subject: |
Yes, they will compress. That is how they apply pressure to the seals. If you reuse puse rod tubes, just stretch them back out about 3/8". _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Apr 10, 2005 11:10 am Post subject: |
Ok cool that's what I thought just wanted to make sure before I did it.
Entirely different setup than the type 4 that I am used to. _________________ Sean
