Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Apr 27, 2015 12:26 pm Post subject: Re: CENTER CONSOLE |
ronbug73 wrote: |
Tram
i thinking about CENTER CONSOLE like you made
Tram center console
Ron |
That didn't work out- the driver's foot was way too restricted. Did you see the upgraded version?
[/img] _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
ronbug73 Samba Member
Posted: Wed Apr 29, 2015 1:43 am Post subject: CENTER CONSOLE |
Hi Tram
we think to make the center console around the radio that will be under the inside unit end than to make it nero like you did for the driver foot
Ron |
Posted: Fri May 08, 2015 11:25 am Post subject: hose |
Hi Samba
we begain with the hose.
we will put it in the center. the draier will be under the right fender
next week i hope we will finish
Ron |
Posted: Tue May 12, 2015 8:15 am Post subject: up date |
Hi Samba
this week is the hose line week
condenser hose
the system to expand the hose
after we will use special tool.
the draier
Posted: Tue May 12, 2015 8:19 am Post subject: Beny |
Beny from Dr Bug israel a self-educated machnic. he only works on air coold vw end porsche.
thank you Beny
i think he look like Tram
Ron |
Posted: Fri May 15, 2015 9:59 am Post subject: the end |
Hi SAMBA
some up date
the trunk the huse to the draier
the fuses
the bracket
the engine
Posted: Fri May 15, 2015 10:03 am Post subject: working |
Hi
yes we finished its works so cool
with the radio
its time to say thank you
Tram
Donnie
Roy
Beny
end Samba
thank you
Ron |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
miomio Samba Member
Joined: November 21, 2007 Posts: 124 Location: SAN JUAN, PR
Posted: Mon May 18, 2015 4:20 pm Post subject: Re: hose |
ronbug73 wrote: |
Hi Samba
Ron |
That's some nasty crack, I think. |
Posted: Sat May 23, 2015 8:43 pm Post subject: yes |
yes i know about the transmision nose crack
i dont know i dont have problem. end i dont know how to weld it. |
Walter64 Samba Member
Joined: December 06, 2013 Posts: 146 Location: Sydney
Posted: Fri May 29, 2015 3:54 am Post subject: Re: CENTER CONSOLE |
Hi Tram, just need a little help, where is the condensor installed?
Tram wrote: |
ronbug73 wrote: |
Tram
Tram center console
Ron |
[/img] |
_________________ VW fan & Real Estate Agent at www.argyproperty.com.au
66 RHD teak T34 karmann |
Posted: Fri May 29, 2015 9:53 am Post subject: |
Walter- on that early car space in the front beam area where the condenser usually goes on later cars was way too limited so we installed a universal thin parallel flow condenser with a thin line cooling fan attached in the area above the transmission which worked out perfectly. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri May 29, 2015 6:01 pm Post subject: |
Hi Tram, thanks, my dilemma is my car is a T34 which does not have enough room between the spare wheel well and the front beam, (and i will not be cutting the body to accommodate) so then it should go above the transmission as you mentioned. My concern was is it going to get enough cold air even with a cooling fan? According to what you are saying, it should be Ok. I also wanted to install an oil cooler. Is there enough room for both? If both were installed, will they cool properly? _________________ VW fan & Real Estate Agent at www.argyproperty.com.au
Posted: Sat May 30, 2015 3:48 am Post subject: inside unit t34 |
Hi
someone have a picture of the inside unit of the T34?
beacuse the car never imported to the usa, end other market didnt
get the ac as an option
RON |
Posted: Sat May 30, 2015 11:05 am Post subject: Re: inside unit t34 |
ronbug73 wrote: |
Hi
RON |
Frigiking made a unit for the Volvo p1800 that was also used for the Type 34 as I recall. I have one- I will try to photo it later.
I have also seen a "Kuhlmeister" under dash unit as was used in Mercedes W110/ 111/ 112 cars in a Type 34. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat May 30, 2015 3:22 pm Post subject: |
Tram, I never thought about a kuhlmeister. Looking photos of the unit, it seems it could be a nice fit with some mods. _________________ VW fan & Real Estate Agent at www.argyproperty.com.au
Posted: Sat May 30, 2015 3:37 pm Post subject: |
Walter64 wrote: |
Tram, I never thought about a kuhlmeister. Looking photos of the unit, it seems it could be a nice fit with some mods. |
They made a version with dual small "barrel" fans right on the rear hanging down off the bottom of the unit. That's the one I saw in a 34 years ago. If you have a later 34 with the 'woodgrain' dash, you could make the face of the Kuhlmeister match the woodgrain and vinyl dye the padded surround to match your dash pads for a factory installed look. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat May 30, 2015 3:42 pm Post subject: |
Walter64 wrote: |
Hi Tram, thanks, my dilemma is my car is a T34 which does not have enough room between the spare wheel well and the front beam, (and i will not be cutting the body to accommodate) so then it should go above the transmission as you mentioned. My concern was is it going to get enough cold air even with a cooling fan? According to what you are saying, it should be Ok. I also wanted to install an oil cooler. Is there enough room for both? If both were installed, will they cool properly? |
Yes, the A/C on the Notchback pictured above is actually very cold with the condenser and attached fan there. As to an oil cooler, the answer is that I don't have enough experience with those to really know. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat May 30, 2015 4:50 pm Post subject: |
Thanks Tram, have you or has anyone ever seen a Kuhlmeister or Frigiking installed in a T34? _________________ VW fan & Real Estate Agent at www.argyproperty.com.au
Posted: Tue Jun 30, 2015 8:26 am Post subject: summer |
ok
summer is here with 32c Celsius degrees end its very humid
but inside my fastback its cool
happy summer |
