Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Sun May 17, 2015 9:12 am Post subject: |
racoguy wrote: |
Common knowledge is that the T14 door seal is too short for a T34 but my question is where is the original door seal supposed to finish?
I purchased an extra T14 seal to use the profile to extend the seals on both doors but don't know where they finish, one would assume to the bottom door hinge? |
If I remember right it is at the bottom of the lower hinge. I used this link to help, and it might help you out as well.
http://www.type34.com/library/16-step-by-step/993-door-seal-restoration
I also purchased an extra seal just to lengthen my existing seals. It worked out ok, but I still needed to work on the door post side to get things to work better.
The lower dash pad looks sweet John. Nice work.
As for the knobs, they came out great. That style of knob was always fragile, and I had several sets of them that just crumbled if you even looked at them. Making them out of aluminum is what VW should have done. On my own car, I bought some billet knobs from Mid America, and just replaced them. They were the next design style of knob though, but when you want to roll the window up or down, having good knobs does make a difference. As to paint, or no paint, that's up to you. If you polish them up, you could leave them alone. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Sun May 17, 2015 7:16 pm Post subject: |
Thanks fellas I'll look at extending the door seal a little, don't think there's any major problem grafting a piece on especially in a place where its not really even seen.
Clatter you're not wrong man, been in that situation too many times having a half a** job presented with the hand out for payment so after years of disappointments I just figure out how to do it myself........you sort of have to.
Anyway last night I machined up some new knobs, much happier with version 2
_________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
Posted: Sun May 17, 2015 7:27 pm Post subject: |
Clatter wrote: |
racoguy wrote: |
You just have to keep persevering and pushing on with stuff like this, it's the only way to get it done...........well other than farming it out to another shop that is. |
My vote is for you to paint the wheel spacer and shifter, too.
Seems like the wheel spacer wants to be the same as the column,
And that shifter would be totally one-off if it were ivory like the early beetles/Ghias, etc.
JMHO
Having been tortured by billet, (living in California in the 90s),
I have become quite sensitive to it.
*Love* this build!
Can't help but read it over and over.... |
I like your thinking, but would probably paint the wheel spacer black and do the bulk of the shifter in Lotus white with some black through the milled holes.............hmmmm more work..... _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Tue May 19, 2015 1:08 pm Post subject: |
Finished off the rear compartment carpet with some foil backed underlay from TMI, doubt it will do much to dampen the aircooled clatter in the back but that's all part of the charm with these old cars
I'm really glad I went with the more expensive carpet in the end as it does look really nice I think.
I'll have to start testing and finishing the electrics soon, just ordered the last couple of parts I needed for that mainly the interior light from Stoddard.
Is there any known sources for the smaller diameter foil hose / heater hose??
Most of mine is very brittle and damaged and it would be nice to be able to replace it all.
F.BOUTIER Samba Member
Posted: Wed May 20, 2015 3:22 am Post subject: |
Hello John ,
Is it the 28 mm inner diameter heater hose ?
Where did you find some , please ?
Franck. |
Posted: Wed May 20, 2015 3:42 am Post subject: |
Ok John , thank you !
I sent you an e-mail for the clamps.
Franck. |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Wed May 20, 2015 5:13 am Post subject: |
Wolfsburg West has a pretty good selection of these hoses. _________________ 69 Fastback Build
Berg5 Build |
Posted: Sun May 24, 2015 12:22 am Post subject: |
Next on the list was to make a new strip of dash vinyl to hide the painted dash along the window edge, since I still had the original it was easy enough to copy it and make a new one from the same grained material as the door tops.
Had to heat it to be able to curve it in the corners and actually made it in two pieces since my roll of material wasn't wide enough to do the whole thing in one go, coat of black vinyl paint and glued it in place.
By the time i'm done I could probably write a book on restoring this car!
Bought another heater during the week which meant I had to make my box and vinyl frame longer again to be able to do the dash tops, that was yesterdays work along with getting everything ready and set up again for what hopefully will be the last round of vacuum forming.
Early this morning I decided to have a shot at doing the lower dash and to be honest was pretty nervous as you really do only get one shot at it.
Things didn't go all that well as it turns out and in hindsight I should have gone about it differently but what's done is done.
The vacuum has such force that if the item is not supported correctly it will distort under vacuum which is what happened here, not much I can do about it and after a few hours of corrective work I at least have it in the car.
I'm far from happy with the finished result but I'll live with it for now, all bolted down it looks ok enough.
Probably more because I know where all the problems are but when you consider what most of us T34 owners start off with its not all bad.
Decided against doing the dash top for now, I'll think more about how I'm going to tackle that as that really does have to be right.
MonT3 Samba Member
Posted: Sun May 24, 2015 8:55 am Post subject: |
That lower piece looks amazing. I have to ask about the grain of vinyl you’re using. Is it the Madrid patter or another being used? I’ve been looking at grain here locally but haven’t seen anything close to what my dash has. I haven’t read in the grain threads of a matching grain. Is the grain you’re using the closest to what you had? If so, could you share the patterns name? I’m looking at this site and plan on contacting them on their vinyl products, specifically the Wallaby Black. http://foammart.com/index.php?nsc=automotive&pcat=vinyls#categories _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
gregson1 Samba Member
Posted: Sun May 24, 2015 9:14 am Post subject: |
Looks great! I'm also curious about the vinyl grain used.
The factory painted the metal dash vent area black, too. |
t3kg Samba Member
t3kg Samba Member
Posted: Sun May 24, 2015 1:13 pm Post subject: |
Interesting question, the vinyl used for dashboards is not your ordinary upholstery type vinyl. I would describe it more as plastic rather then vinyl as its very rigid / stiff hence having to heat it to over 150c to make it pliable enough to vacuum form.
The roll of material I bought I just got lucky with, there was 1 company in all of NZ who had a 80cm wide roll in stock so I bought the whole roll, previous to that I'd not had much luck finding dash vinyl and I guess I got lucky with the grain as it does look very close to original.
The one company in the country doing dash re skinning wouldn't sell any material as another upholstery supplier imports the material only for them.
As you can see, grain on one side and smooth on the other almost like a sheet of plastic, most of these materials are never black either they come only in a couple of colours which have to be vinyl painted to match what you have. I'm sure it will be available in the US like everything is.......
NZ is another story.......
That reminds me, anyone reproducing glove boxes? would save me making that as well.
Posted: Sat Jun 13, 2015 3:26 am Post subject: |
Been sourcing and waiting for a few of the little parts needed to finish off certain jobs on this, some parts are better than others as per the norm with aftermarket stuff and usually you have no choice so what's available is all there is.
I was pleasantly surprised with the interior light from Stoddard, looks really nice, on the flipside the interior finger guards from KGP&R are absolute shi#te but with modification they just work and were cheap so...........
After a few weeks break from vacuum forming I decided today was the day to get er done so to speak and put this process to bed, at one point I was close to ripping it all off and starting again but managed to save it through perseverance.
Ran out of vinyl paint so that wasted a good couple of hours finding some more as I was determined this was going to get done today!
From here there's a couple of hours finishing off wrapping the vinyl over and gluing down / trimming edges etc.
Not half bad after a coat of black! Paint was barely dry and the dash is in my hot little hand on it's way over to the car to mount this sucker.
Pad bolted down completed another step in the interior, also installed the glove box which amazingly was good enough to go right back in after 52 years of service.
Scott's awesome glovebox decals were next, man are those things fragile!
All went well though but a lot of care and patience needed...........patience is not my strong suit..........
Last thing for the day I had a go at installing the windscreen by myself as there was no one here to help, the rubber doesn't want to stay on the glass too well but once you install the trim it seems to tie it all together.
A trick I've always used to make sure the rubber seals is to spray a rust preventative like Tectyl on the outside edge of the glass and then install the seal, with the seal on I again spray the Tectyl on the rubber itself and on the window frame then install the glass.
The screen went in easy as, started seating the rubber at the bottom using the weight of the glass pushing down and once the whole lower lip was seated I gave it a good bash with the palm of my hand, then worked my way up each pillar with one hand pushing from the outside and the other pulling the rope.
Final stretch along the roof meeting in the center it was in, a good number of slaps seated the glass in place and hopefully it seals.
The only hassle with the rust preventative is it gets on everything and everywhere but once cleaned the result is awesome.
I always find that a project feels like its turned a corner once all glass is in and certainly today was one of those days, more parts off the floor / shelves and back on the old girl.
I'm quite amazed how good a shape this 50 year old glass is in, sure there's some de-lamination and a chip or 2 but still pretty damn nice. Pretty glad it's back in there instead of leaning against the wall looking to get broken.
Posted: Sat Jun 13, 2015 3:33 am Post subject: |
I also bought a bunch of these funky metal ties but had to do a bulk buy to get some, result is I have a lot of spares to help others.
Let me know if you need some, they are cheap and I can post overseas.
t3kg Samba Member
