Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed May 27, 2015 8:07 am Post subject: Bugpack hide away muffler on Ghia |
Just installed a Bug Pack hideaway muffler on my ghia. I'm glad I heeded the warnings that it might not fit and need modification, and therefor bought the painted version. I had to cut the tube from the header to the muffler, at the muffler, and rotate the muffler to near vertical to avoid it hitting anything. I then had to cut off at the muffler and rotate the tail pipe assembly accordingly. I still had to slightly dent in the bottom of my right rear wheel well to gain clearance. All in all, I'm pretty happy with the fit and sound. I still have to weld on a tab for a hanger, and strip and repaint it with VHT. The tail pipe end needs a slight trimming to avoid scraping when I back down our steep driveway approach. My ghia is slightly lowered and running low profile 15" tires, so that wouldn't be a problem with a stock height ghia.
_________________ 1958 Karmann Ghia owner |
c21darrel Samba Member
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Thu May 28, 2015 9:33 am Post subject: |
What headers are you guys using , merged or 4:1 ? Could have different outcomes of geometry. I have thought about this route because my dual QP have gotten banged up alot because it sits so low.
More pics? |
Posted: Thu May 28, 2015 10:31 am Post subject: |
Here's a rear view. The header is the standard bugpack ceramic header. I'm not sure how to tell 4 into 1 vs merged. Inform me if you will.
Posted: Thu May 28, 2015 11:20 am Post subject: |
Northof49 wrote: |
The merged header, like darrel has , Is longer in the area where the four pipes join , allowing the exhaust flow to 'merge' for a more efficient escape.
I have 4:1 header so it might mean having to do the cut and weld if i go that way. Good to know info, Thanks. |
Posted: Thu May 28, 2015 2:14 pm Post subject: |
I like the sound. Not as noisy as a Mondo, which I currently have in place, but similar sounding, only 2/3 as loud. It is a "turbo" muffler though that comes with the hideaway kit, so it's not as quiet as stock. _________________ 1958 Karmann Ghia owner |
