DannyT3 Samba Member
Joined: September 03, 2012 Posts: 135 Location: Norway
Posted: Tue May 26, 2015 11:45 pm Post subject: Help with roof |
I have this nice 1961 T1 chassis with almostno rust, only minor on the surface. But have this dimps on each side, probably after the po lifting it with straps..
What do you suggest I do, trying to pull them out, or weld in new piece from donor car?
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed May 27, 2015 8:08 am Post subject: |
Like that on both sides? Hopefully in about the same spot.
While it does not look that bad, I say B: Weld in from donor. If you already have a welder and know how to use it.
It will be quicker than pulling/bumping/filing/filling/sanding _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Wed May 27, 2015 3:18 pm Post subject: |
Thanks mate, no, not that severe on the other side, but same spot. Probably going to weld in new metal, need alot of force to get it out, and can't easely get access from the back side. Probably have to unfold the rail on the new piece, and weld it in two section...
Danny |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed May 27, 2015 4:19 pm Post subject: |
You could even weld on a whole different roof section/clip that was cut off at the A,B & C window pillars, but that is probably not necessary in your situation. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
