liken127 Samba Member
Joined: June 27, 2013 Posts: 102 Location: Upland Ca.
Posted: Tue May 26, 2015 7:14 pm Post subject: Rear Shocks |
Just got the new back shocks from the TTS Got the good gas shocks!
but with the spacers on both sides, it hit's the rear arm? also with the
pan up on the stand, It is a little short! may be 3/4"? is there some thing
I am missing? I thought the shock should have a little travel left ?
Can the spacers be together? just don't look right. thanks for the help. |
Posted: Wed May 27, 2015 7:17 pm Post subject: |
Sorry the shocks are the KYB gas adjust, But they are gray, just like the fronts? some of the forums say they are white? did the TTS make a mistake?
It would not be the first! Thanks for any info. on this. |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
randybriscoe Samba Member
Joined: December 26, 2007 Posts: 241 Location: chicago
Posted: Fri May 29, 2015 10:26 am Post subject: rear shocks |
having a similar issue here...I'll post some pics and details ASAP |
Posted: Fri May 29, 2015 6:50 pm Post subject: |
Thanks Joe, Randy picts would good. really is the last thing before I take it off the stand! |
NY thing Samba Member
Joined: March 23, 2010 Posts: 100 Location: Queens New York
Posted: Sun May 31, 2015 12:16 pm Post subject: |
Kyb recently changed the color of their shocks. The ones that were white are now gray but the rep told me that they are the same as before, just a different color. I find mine to be a tad short too. |
GI Joe Samba Member
Posted: Sun May 31, 2015 7:14 pm Post subject: |
Joe, Yes! that may be it! If the arms are indexed to much to the inside,
that may make them hit the arms. I will read the manual again and see
were I went wrong! As far as being short, Will the shock not pull apart,
in time? If we are using them as a limiting strap?
thanks again for the help. p.s. got some picts from the painter on Friday,
he is almost there!! cant wait |
GI Joe Samba Member
Posted: Sun May 31, 2015 10:39 pm Post subject: |
The shocks on the rear of this car hit the swing arm & the shock mount. |
Posted: Mon Jun 01, 2015 7:14 pm Post subject: |
Yes, that is what is happening to mine also! Did you have the arms off?
Joe posted may be in the indexing up on upper mount.
I will be checking mine this weekend, if not sooner! will let you know what
I find. Will try to get some picts also. |
GI Joe Samba Member
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Wed Jun 03, 2015 6:23 pm Post subject: |
Ron and I have done many no problems it will straighten out when the body goes on the shocks need to have weight on them first. sometimes I need to wait to put the top bolt on after the body is on.
Posted: Thu Jun 04, 2015 7:22 pm Post subject: |
Ok I checked the rear arms and they are right on the 19-3/16th" from center
of trans to c/v flange! So I bolted the bottom of the shock, and tied the frame down, and
with a little push up with jack, it went on the top. let the jack down and it
went down to the stop! still a little close the arm, Touching it!
I am hoping to have it on the floor this weekend, Will but some weight on
it and see if it moves away a little. Thanks Again for all the help and info
as I move through this project. We will work on posting pics. this weekend.
Next I move to the motor part |
